04 gto headers
04 gto headers
I am looking for headers for my 04 gto. I have straight pipes ran right now still with the cats intact and I want the headers to support a future procharger. Any suggestions on brand, size, etc...
I bought the engine from this guy. He still has the headers from the car:linky:
https://ls1tech.com/forums/parts-cla...cam-stall.html
Pretty decent guy to deal with.
i have a set Dynatech with a jet hot 2000 coating in black, they are for sale if you want to get a used set. i loved them i just had to upgrade to a set of custom 2" primary headers for my new 454 build. send me a pm if you want.
Not really much difference unless you are building a really high HP motor. The 1-3/4" fits better and probably makes more torque on modestly modded motors.
EDIT: I originally said 1-7/8", but meant 1-3/4" (I changed it in the post). That said, I have 1-7/8" Kooks and love 'em. But, I'm putting down about 575 hp with a 150 shot of giggle gas. A bolt-on only car would be perfectly fine with 1-3/4" headers.
Its like the saying goes " you get what you pay for". Now i know people will come on here and say pacesetters arent that bad but if i were you i'd go with kooks, arh, dynatech. As for size go 1 3/4 especially since you wanna procharge.
I have the Jet Coated Pacesettter w/Jet Coated catless mids. I do not drive the car in the winter though either. Anyways I have no issues with mine and had a huge gain in hp with them. Also with mine, I'm not a baller so I went with what I could afford at the time.
I have a set of Pacesetters for sale on this forum!!! The amount of money you can save over buying Kooks you can buy a cam, springs and 243 heads!!! JMO!!!
https://ls1tech.com/forums/pontiac-g...armorcoat.html
the pacesetters will make just as much hp as the high dollar 1 3/4 kooks but if it is worth the extra 6-700 bucks to put it in the sig go big. but the steel ones will only last 4-5 years witch is way longer than i ever keep a car .but the exhauste could give a **** wether its flowing through a $1000 set of stainless or a $350 set of cheap ones as long as the pipe size is the same.
also 1 7/8 headers on a ls1 is way overkill for a ls1. 1 3/4 is fine for all the 6-7k shift points . i actually have a dyno graph through pace setters pulling to 7200 rpm.it is low but it is through a loose *** converter and a 9" and the car runs 10.90's n/a. it was my gto i sold it but the guy that bought it put it on a portable dyno chassis at ls fest. but this is through pacesetters and 3 " flow masters i did have to grind the end off 1 or 2 of the fender reinforcemeant bolts but that was it.2 minutes with a grinder to save 6-700 bucks .thats money that can be spent on better things
