where to add a wide band sensor
i need to add a wide band sensor to the gto ,
i have the rt header off , put it in the collector or in the cat less mid .
the catless mids i have are not coated ,the kooks header is .
i also have catted mids
so this would make it where i would not need to run the wide band all the time . just use it to tune ?
any ideas?
any ideas?
Ideally, you would put it in the header near where the front O2 sensor is located. That said, I installed mine in the front section of the mid pipe, because I didn't want to go through the hassle of remove the header. I had a muffler shop install the wideband bung. It seems to be working fine for me in the mid pipe. Some people just turn off the rear O2 sensors and use one of those bungs for the wideband.
