FAST 92 TB issue on 04 GTO
Restricted User
Having an issue with an 04 GTO. The pedal will go wot but the throttle blade doesn't. While the pedal is depressed the traction unit has play where the cable from the tb connects and if I turn it slightly it will go wide open but not by the pedal. When going wot in the log it only shows 85% throttle. Anyone have this problem? Any possible fix for this? Is their a cable that I can get to elliminate the tcs completely and have a direct connection from the pedal to the tb? Let me know....
