victor jr with 4150 tb on gto - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
Thread Tools Search this Thread
Old 02-12-2012, 04:01 AM   #1
ssinister550's Avatar
Default victor jr with 4150 tb on gto
who has done it and what exactly is needed aside from manifold and tb? I.E: throttle cable bracketry/setup etc and with a 4150 tb is there room under an 05/06 hood for a traditional round filter or do you need a hat? thanks all
ssinister550 is offline   Reply With Quote
Old 02-12-2012, 05:14 PM   #2
come on i know someone has done this lol
Old 02-13-2012, 03:32 AM   #3
done it and went back
the bonnet in this pic barely fit under the rk hood , and that even included cutting the bottom out of the hood , and the bonnet robbed about 5mph from my 1/4 times
s/c'd cav is offline   Reply With Quote
Old 02-13-2012, 08:04 PM   #4
badass man thanks. is there any way you can give a decent list of parts for throttle linkage, vaccum lines/fittings and fuel line fittings etc? im sure i could figure it out but this is my dd so the less downtime the better and a parts list would be greatly appreciated. THANKS!
Old 02-14-2012, 01:05 AM   #5
i actually got it used from my neighbor , he had it on his turbo truck
it did have the universal cable bracket made for the LS intakes , and i had the factory bracket mated to it
the cable end came from LOKAR , and you have to cut the end of the stock cable
the map was a 1/4" brass fitting , and i think a 3/8" for the brake booster , everything else was off the edelbrock tb i believe
i dont remember the size of the fuel rail fittings i believe -6 , everything came off my LS6 with speed inc rails
in my honest opinion , its not worth it for a n/a motor , in a turbo or procharger app it would be worth it , on the street i didnt notice much difference , just at the track it never did better than a mid 12 , when it should low 12's
i also think the fast 75/8 i went to after this was alot better option , i also had to get a new throttle cable since i had cut mine , and they are getting harder to get ahold of
this is the hood i had to use , and cut the bottom out on it to clear the bonnet , and there was about 1/4" clearance if that
Old 02-14-2012, 09:28 PM   #6
well do you want to sell that setup then if your not happy with it? lol
Old 02-14-2012, 09:30 PM   #7
sold it all about 18mths ago , lol
thats how i got my fast , lol
ive still got the hood forsale though , but i think you are to far for a local pick up
Old 02-15-2012, 12:15 AM   #8
oh damnit! yea no offense but im not really a fan of that hood, although i am coming to Phoenix next weekend to see my parents lol. oh well thanks for all the info anyway!
Old 02-15-2012, 12:19 AM   #9
yeah im not really a big fan of it either , but it was the only hood with a high enough center , short of the old DMS cowl hood , and the sunoco hood
for the ultra cheap price i got it for , it was well worth the price , if you wanna see the hood and the hole i cut in it in person , pm me when you are in town , hell for the price it might sway you into it too , lmao
Old 02-15-2012, 04:02 AM   #10
chance575's Avatar
I'm running a victor jr with a elbow, pic in sig
chance575 is offline   Reply With Quote
Old 02-15-2012, 09:07 AM   #11
402GOAT's Avatar
I believe it has been proven time and time that the Vic jr is a great intake. But when combined with an elbow, the flow and performance goes waaaayy down. I've know a few people to be really disappointed with this setup. Like said above, the elbow is more for forced induction.
402GOAT is offline   Reply With Quote
Old 02-15-2012, 10:38 AM   #12
mark21742's Avatar
I had to cut my hood and add a small scoop, but I'm running and love the Edelbrock proflo xt
mark21742 is offline   Reply With Quote
Old 02-15-2012, 10:57 PM   #13
haha ok i might just do that! thanks again sir!
Quote:
Thats official, this is why i want to run a 4150tb on top of it and i was hoping that i could just fit a traditional round carb style filter on it, but looks like that wont be happening. Hell maybe ill just run the tb open no filter, whats the worst that could happen on a dd street car? ill figure something out. thanks for the input guys
Old 02-15-2012, 11:33 PM   #14
sounds good , just send me a pm if you do , and i ran it open at the track , with the rk hood i have , the scoops were open to the tb
i was originally thinking a velocity stack style air cleaner , kinda like this one , but i didnt want to leave the whole thing out in the open , since the car sits outside
Old 02-15-2012, 11:49 PM   #15
yea i have a carbon fiber 05/06 replica hood w open scoops. I wonder if a lower profile filter like this would fit:
http://www.holley.com/120-148.asp
worst case i might go with a vfn sunoco style hood for more room, thats probably my favorite gto hood anyway, and a cowl would probably be more beneficial than a hood with forward facing scoops, since a true functional cowl hood will actually create a low pressure area in the opening. With a forward facing scoop that wont happen till about 150mph
Old 02-15-2012, 11:53 PM   #16
here's a better perspective on the profile of this filter
Old 02-16-2012, 12:06 AM   #17
forward facing works better than alot over-think it , look at all the top classes of drag racing just proves that point
while most think of the ram-air as being 100% force feed(aka free boost) , most of the gain comes from getting fresh moving air
ive never liked that filter , the base isnt shaped for air flow into the carb/tb , and the filter is just foam , and the last i remember there isnt alot holding it into the assembly , id rather use a k&n or paper filter for a DD
Old 02-16-2012, 01:10 AM   #18
most of the drag racing classes your referring to see speeds of 150mph plus, so yes forward facing will work to their benefit, if you research forward facing scoops though, you'll find that they don't start seeing pressure above atmospheric until about 150+ mph depending on conditions, until then it merely lets ambient air into the engine bay, and even by 200mph there usually isn't more than 1psi above atmospheric pressure inside the scoop. A cowl induction scoop on the other hand, will create a low pressure area around the opening due to the high velocity of air traveling over the scoop, effectively pushing air into that opening, and this can begin to happen at much lower speeds. Which would benefit a street car or drag car that doesn't see speeds as high or much higher than 150mph. This was discussed quite a bit when i attended SAM, you'll notice that the fastest naturally aspirated lsx camaro on record (SAM's 99 h.o.ss, 8.12 @170mph) runs a cowl hood, but that thing is getting to the point where it wouldn't surprise me if they switched to forward facing soon, based on their trap speeds lately.
and the base of that cleaner may not be 100% optimal, and may not be as functional as a velocity stack style inlet, but for a low pro compact cleaner it is actually rather theoretically correct, and matches the style of throttle body/carb pans found on most race cars- flat with a small radius flowing into the o.d. of the carb or t.b. here's what most race car air pans look like, this isn't the best i've seen but gets the point across
and foam may not be as good as a k&n element for filtering, but it is pretty nonrestrictive, a lot of great flowing high performance filters are made of foam.
Old 02-16-2012, 06:05 AM   #19
mark21742's Avatar
I personally don't like the look of them, but would a large cowl induction hood allow the air cleaner to fit, and if you could seal the airflow from the higher pressure cowl area to the air cleaner would that net better gains than a forward facing scoop?
Old 02-16-2012, 09:16 AM   #20
Quote:
I believe that with the sunoco vfn cowl hood for the gto, both of the above questions are definately possible. The problem with hood scoops is you can only try to measure gains at the track, as its hard to simulate driving conditions at speed on the dyno. Either way it would definately be more theoretically correct. The sunoco hood is also pretty badass lookin imo bc it matches the rounded lines of the gto:
oh and i forgot to add, for the best functionality of a forward scoop, it needs to be as high or higher than the roofline of the vehicle, as low as our scoops are, most of the air is simply passing over top of it. take note of the placement of this pro stock hood scoop in relation to the roofline:
Related Topics
Thread Thread Starter Forum Replies Last Post
Wtb: 4150 throttle body brandon0212 Parts Wanted 2 06-21-2016 02:45 PM
Need a Fast 4150 TB with sensors qnitro Parts Wanted 0 11-17-2014 10:24 PM
WTB 4150 or 4500 T/b 98blueSScamaro Parts Wanted 1 06-25-2014 10:39 PM
wtb 4150 tb george g Parts Wanted 4 01-23-2013 09:21 PM
Tags
air, carburetor, cowl, facing, forward, gto, hood, install, jr, na, pan, scoop, scoops, sunoco, vfn, vic, victor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
