Pontiac GTO 2004-2006 The Modern Goat
will a 235/40/19 fit
Old 02-19-2012, 10:56 AM
lo&sloSierra's Avatar
Default will a 235/40/19 fit
Im running a 235/35/19 on the rear of my car now with a 35mm off set on i think a 8 in. wide wheel, will a 235/40/ 19 fit on stock suspension, its an 06 if it matters
Old 02-19-2012, 03:22 PM
Dyno Junkie's Avatar
Should fit on the rear, but definitely will not fit on the front.
Old 02-19-2012, 09:09 PM
Death{AW}'s Avatar
why are you running such narrow tires? yea those will work easily on back unless you are lowered like crazy
Old 02-20-2012, 08:24 AM
redtan's Avatar
They'll fit sure, but if you hit a big bump or launch hard the taller tires will probably rub on your fenderwell.
Cruising it will be fine as you should have plenty of gap between the top of your tires and body, unless you are slammed.
Old 02-21-2012, 07:34 PM
scphilli's Avatar
Skinny pants
Old 02-23-2012, 10:11 PM
Okay so I was wrong the rear wheel is a 8.5x19, with a 45mm offset, how big of tire can I stuff? And its not lowered. Thanks.
Old 03-02-2012, 01:02 PM
redtan's Avatar
With an 8.5" wheel and that offset, the most you can go is a 255 tire.
Quick Reply: will a 235/40/19 fit
