Pontiac GTO 2004-2006 The Modern Goat
2004 gto fan is staying on when cars off?
Old 04-08-2012, 12:18 AM
quadd2244's Avatar
Default 2004 gto fan is staying on when cars off?
Posting this for a friend. He has a stock 2004 gto with under 60k miles. Here is what he messaged me
Had a problem w/my high speed fan relay few months back (the fan would stay on after the car was off but when I took it out the fan would shut down so I replaced the high speed relay. Had no problems for a month. Then I turn the gto off today and the high speed fan was stayin on. I popped the hood and took the relay out and it still stayed on. I even took out the low speed relay and it still wouldn't go off. So today I changed the coolant temperature sensor in hopes that it would help. But no the fan still stays on after the car is off
Any suggestions or ideas guys? I really have no idea what to tell him as i have no idea about the cooling systems on these cars
Thanks guys!!
Old 04-08-2012, 02:01 AM
402GOAT's Avatar
look at the stickies above about wiring rubbing in behind the glovebox. seems like it has to be a wiring problem to me if he pulled the correct relay and the fan stayed on.
Old 04-10-2012, 09:14 AM
Rauq's Avatar
I would assume that if there were a connection to heat he would have pointed it out... stock tune has an allowance to keep the fans running after the car is turned off if coolant temps are above a certain level. Although the car would do its best to keep coolant temps below that threshold while it was running (it's really high, like 284 if I recall), it could still be related. I set that temp to something artificially low to keep the fans on when I'm at the strip.
Old 08-16-2012, 02:55 PM
Daniel Cooley's Avatar
this problem is happening on my 04 GTO as well. i have changed everything i can think of. the fan will come on by its self after the car has sit for a while.
Old 08-16-2012, 05:32 PM
v8
17,16,15,14,13,12,11 Drvr
v8's Avatar
open relay panel under hood, tap on the fan relay, they get stuck sometimes.
Old 08-16-2012, 06:23 PM
i have change them and it still runs. i can tap the dash and it will go off. it always comes back on.
Old 08-18-2012, 07:05 PM
ASSuming On The Tree
audacious nick's Avatar
How long will it run for? The fans run even after you shut down if the engine reaches a certain temp, then it shuts down.
Old 08-19-2012, 11:56 AM
Summerwolf's Avatar
Tap on the fan relay. Mine got stuck open, tapped it a few times and it stopped doing it.
Quick Reply: 2004 gto fan is staying on when cars off?
