600 degree brake fluid
Trying to find where i can purchase 600 degree brake fluid. Actually needing it for my clutch fluid as i believe its the same. I have tried looking at discount auto and advance but didnt see it. I did see some sold on a couple performance websites but it didnt really give any specifications on it. I will be doing my brakes and need to replace the fluid as well soon so i wouldnt mind buying something good so i can use it for both. I know the higher rating will help with overheating and hard driving
I personally use Wilwood EXP 600+ in both my clutch and brake system.
It has worked awesome for me so im happy to recommend it.
When I was looking for a good Clutch/Brake fluid I wanted a good one that didnt cost a crazy amount and this product kinda hit that balance well.
There are higher rated fluids, and more expensive ones, but for a mostly street car, the Wilwood does really well.
I ordered mine from Summit, fyi. One bottle did my clutch and brakes both with a bit left over.
Hope this helps.
--Glenn
Hope this helps.
--Glenn
Hope this helps.
--Glenn
Hope this helps.
--Glenn
