Pontiac GTO 2004-2006 The Modern Goat
Corvette LS2 Fuel Rail Covers on GTO
Old 06-14-2012, 05:19 PM
409CISecondGen's Avatar
Post Corvette LS2 Fuel Rail Covers on GTO
So you want to put Vette LS2 FRCs on your LS2 GTO?
Here's what you will need:
-1 13mm socket
-A dremel with a cutting bit
-A file
-A set of LS2 Corvette Fuel Rail Covers
Step 1: Getting Started
Use the 13mm Socket to remove your factory strut bar.
Also twist off your oil fill cap.
Then remove your stock GTO Fuel Rail Covers.
Just pull up and they will come off.
Your engine bay should look like this when you're done.
Step 2: Modifying The Passenger Side Cover.
Here is what your FRCs look like on the passenger side.
You will need to clearance them for the oil dipstick with your dremel.
The first cut you should make with your dremel is extending the dipstick cut over about two inches.
I made a neat trapezoid shape.
Now cut up and over with the dremel another square inch or so.
File down the shavings and clean up your cuts.
You should be able to secure the FRC with all 4 OEM mounting points.
And now the Passenger side cover is done!
Step 3: The drivers side cover.
You will need to make 2 cuts.
The first is to clearance for the GTO's fuel line.
Cut the lips off of the plastic that extends down where Corvette fuel line comes out.
The second cut is to clear the GTO's brake booster.
Cut a square out about 2.5 inches in and down.
Now would be a good time to wrap your fuel line in electric tape to protect it from leaking.
Again, file down your cuts to make them look nicer.
You will only be able to clip the FRCs to the fuel rails.
The mounting points on the heads will not work.
Step 4: Finishing up
Put your oil fill cap back on.
Put your strut bar back on.
Secure it with the 13mm socket.
Place your socket and dremel back where you found them.
Vaccum up your mess.
Step back, clean your engine bay(because if you own a GTO and don't keep it clean the GTO fairy will pop out and punch you in the *****), and enjoy your work!
P.S. Sorry everything has a blue tint, I was shooting in a studio the other day and forgot to set my white balance back to auto.
Old 06-15-2012, 05:44 PM
Robofuzz's Avatar
Sorry, I'm really not digging it. You have a GTO, not a Corvette. I don't see anything cool about hacking up Corvette rail covers to put on a Pontiac GTO.
But hey - it's your car.
Old 06-15-2012, 06:37 PM
Well, I personally hate the GTO FRC's. I think these Corvette ones look the best and I'm not going to spend money/time on a coil relocation kit, valve covers, and fuel rails.
I'm also not the only one who wanted to do this, but couldn't find explicit instructions.
http://www.ls1gto.com/forums/showthread.php?t=434198
http://www.ls1gto.com/forums/showthread.php?t=70648
http://www.ls1gto.com/forums/showthread.php?t=353527
http://www.ls1gto.com/forums/showthread.php?t=19766
http://www.ls1gto.com/forums/showthread.php?t=437890
http://www.ls1gto.com/forums/showthread.php?p=7559385
http://www.newagegto.com/forums/showthread.php?t=4715
And CTSV Owners:
https://ls1tech.com/forums/cadillac-...ette-frcs.html
https://ls1tech.com/forums/cadillac-...vers-sale.html
https://ls1tech.com/forums/cadillac-...-frcs-ls6.html
http://www.cadillacforums.com/forums...frcs-what.html
Old 06-15-2012, 09:24 PM
Robofuzz's Avatar
I mean - I could maybe see doing it if you filled the Corvette letters and then did something like put "Pontiac" on them.
But if you like it, that's all that really matters.
Old 06-15-2012, 10:28 PM
Tony's 06's Avatar
They look like they are too far forward, especially with the gray fast under them, that is just my $.02 though.
Why not go with the Holley valve covers and ditch the FRC's?
Old 06-15-2012, 11:19 PM
svede1212's Avatar
Yes the GTO FRCs are bad. These are even a bigger bad. You could just throw a blanket over the engine and really keep it toasty
Old 06-16-2012, 05:54 PM
Robofuzz's Avatar
Bingo.
Old 06-17-2012, 09:39 AM
SJFGTO's Avatar
Nice job and if you dig it, that is all that matters. FWIW I am not a fan. Why put FRCs on your car at all? They are just big thermal blankets for your engine. If you have to have them, put them on only when parked at a car show or your local drive-in...but then...at least have the correct model listed on your FRCs. Personally, I like the old school chrome look. The Holley LS covers are relatively inexpensive, offer several different finishes, do not require a separate coil relocate package and look great. Corvette FRCs on a GTO??? I'll pass.
Old 06-18-2012, 01:56 PM
04ls1gto24's Avatar
I am not a fan but if you like it that is all that matters
Old 06-27-2012, 09:43 AM
adamc45's Avatar
i dont think it looks too bad. but looks better without them tho. love the color of your gto tho
Old 10-28-2012, 06:26 PM
cyclone6liter's Avatar
Default My Corvette FRCs
Thanks for the post. I think these look great on my Goat! I was able to place my passenger side without making the second cut after ever so slightly bending the dipstick tube outward. Also My drivers side sits perfectly flush and mounts to ALL 4 points after routing the fuel line through the Corvette's fuel line relief on the top side just like it does on the Vette.
Old 10-28-2012, 07:25 PM
thehazz12's Avatar
Eh, not a fan, but it's not my car. I just don't see the point. You don't drive a Corvette. You drive a GTO.
Old 10-28-2012, 07:30 PM
Robofuzz's Avatar
Yeah - I just don't get it. It's an LS2, but the Corvette has different accessory routing, etc. It's not like you took a Corvette motor and dropped it whole into a GTO. Rice if you ask me.
Old 10-29-2012, 02:26 PM
Yeah I get it Robo and Hazz, you don't like it . I realized that before I posted thanking 409 for his info. "Rice", Really?... How about "Ghetto ". Well everyone has an opinion but to be honest the covers do serve a purpose of protecting the coil packs and the GTO factory ones have the inherent gas line rubbing flaw as well as being awful to look at . So I understand just wanting to get rid of those. -from the onset The ls2 has always been a corvette motor with a packaging change to the accessory drive and exhaust manifolds thats it. The corvette covers are more of a homage the the origin of the powerplant .And why put Pontiac on them? There hasn't been a Pontiac motor in a goat since before Nixon.
Also thanks for clearing up the obvious, I'm not driving my Corvette WHEN I'm driving my GTO. Got it...
I usually don't respond the Debby downers of the net but I really was just trying to say thank you to 409 .
I am new to THIS forum but not at all new to the scene,and other GTO forums.
.You sure have a way of making a guy feel unwelcome...
Old 10-29-2012, 03:03 PM
Tishkevich's Avatar
Welcome to the internet? Everyone doesn't share your taste. The point of posting is to receive responses on what you're posting about. Good or bad, deal with it. If you've been on the forums else where for a long time, you should be used to this?
Old 10-30-2012, 08:11 AM
Robofuzz's Avatar
Whatever man. You posted up your pics. You have your opinion, we have ours. It's cool. It's your car and if you like it, that's all that really matters.
Old 10-30-2012, 09:53 PM
joeyagls1's Avatar
I do have my on period, my motor creates to much heat from the headers and those causes fires anyways.
Quick Reply: Corvette LS2 Fuel Rail Covers on GTO
