car keeps saying I am very low fuel
It keeps beeping and saying very low fuel, I put 20 dollars of gas in it. I do not know what to do. Is it a fuse that is messed up?
Is your fuel gauge stuck on E? if so then you need to trace it back to the sending unit. Start by unplugging sending unit, then use paper clip to jump the wires on the harness, then turn key on (engine off) and see if it shows full tank on gauge, if it does then all wiring is good and problem is in the sending unit
That sounds like it may be it, but I am not for sure were the sending unit is?
I filled it up and it worked, put in 65 bucks of 93. Thanks, glad I did not have to remove the fuel tank.
Haha, yeah me too, I am like what am I going to have to buy now or fix now that I do not want to really. Yeah it worked, I think the sending unit is use to being very low on fuel and got use to it this is one of the first times I filled it up completely.
Sometimes the sending units will get "stuck" without the fuel sloshing around in there, this could have happened to you. Keeping a decent amount of fuel in the tank will prevent it from happening.
Also, do yourself a favor and try not to run the tank low all the time. Your fuel pump relies on the fuel for lubrication, running it low all the time will reduce the the life of the pump/sending unit.
There's really no reason to be stingy with gas. You'll just have to make more trips to the gas station and you don't save any money by doing so.
So since you didn't answer this, everyone is just going to guess at the problem.
BUT, if you have an 04, your gauge cluster is most likely messed up. It happens to all 04s and it's just something to live with. It'll happen again if you replace it too.
I have it happen every so often. Along with the temp gauge that thinks the engine is over heating, after 2 min of starting the car.
