Pontiac GTO 2004-2006 The Modern Goat
Voltage low.
Old 02-17-2013, 06:50 PM
weisberg16's Avatar
Default Voltage low.
Hey everyone. I have 2005 Gto and have been plagued with voltage issues for the last two months. I have replaced the alternator and battery and still struggling to start the car. My interceptor gauge pod is reading 12.9 volts. When I installed the new battery it read 13.6 volts. The car also struggles to start.. Any ideas? Any help would be greatly appreciated.
Old 02-17-2013, 07:12 PM
Metallifan's Avatar
Is starting the only issue? If so, check your starter connections for corrosion.
Old 02-17-2013, 07:58 PM
weisberg16's Avatar
Well slow starts and voltage dropping as I drive...
Old 02-17-2013, 08:43 PM
Metallifan's Avatar
Do you have an aftermarket audio system? Does your A/C work well?
Old 02-17-2013, 09:09 PM
weisberg16's Avatar
Yes I do have an after market stereo system but its disconnected from the battery because I though that was the problem but nothing changed. The AC does work well and whenever the blower kicks on it drops about .2 volts.
Old 02-17-2013, 09:17 PM
Metallifan's Avatar
The only other thing I can think of right now (and I'm not even sure if these cars have them, I'm used to older vehicles, but it probably does) is the fusible link between the alt output & the starter solenoid. It feeds the positive side of the battery. Check wire continuity end to end. Also, check voltage at the battery and voltage at the alternator separately. Check your grounds. How are your idle RPMs?
Old 02-17-2013, 09:23 PM
weisberg16's Avatar
Here is the schematic for the charging system. Im not very good with the electricals but im learning with this car...Lol
Old 02-17-2013, 09:29 PM
Metallifan's Avatar
Neither am I. Maybe someone with experience could chime in, but there's only one fusible link there and it looks to me like it's coming off the + battery, so I'd check that. If all else fails, take out your alternator and do a bench test. Just do a search, there's a few write-ups on it.
Old 02-17-2013, 09:36 PM
weisberg16's Avatar
Ill test the DC sense and Lamp wires tomorrow and see what I come up with. Ill also try to track down the fuseable link and see if its falling apart. Thanks for all your help buddy.
Old 02-17-2013, 09:42 PM
weisberg16's Avatar
Okay well thats the wrong schematic. The 05-06 gto's use the PCM to control the alternator....
Old 02-17-2013, 09:44 PM
Metallifan's Avatar
You're welcome. Yeah, I REALLY have no idea then. Lol. I'm sure someone with some more experience will get their input in soon.
Old 02-17-2013, 10:08 PM
weisberg16's Avatar
This is the 05-06 gto schematic
Old 02-17-2013, 10:09 PM
weisberg16's Avatar
No fuseable link.
Old 02-17-2013, 10:12 PM
Metallifan's Avatar
Yeah, I don't know. Someone else will have to get their input in.
Quick Reply: Voltage low.
