Pontiac GTO 2004-2006 The Modern Goat
I got some gauges for my pillar, but no direction.
Old 03-17-2013, 08:03 PM
joeyagls1's Avatar
Default I got some gauges for my pillar, but no direction.
I bought some gauges water temp and oil psi, from maverick man carbon, they are nice gauges and match my car, but no directions, I got it all nice and fitted, just do not know where some wires go, for the water temp, where does that go on the head, the cord is about 3 feet long if not shorter, also has spliced wires maybe for the lights, where do they go to metal? Same with oil, where can that hook up to to read off of.
Old 03-17-2013, 09:11 PM
gconnoyer's Avatar
the oil pressure gauge should plug into the harness under the dash in the middle (if you have the certain year that has them)
Also, your car comes with a water temp gauge....
Post a picture of the wires.
Look up what brand gauge they are for directions
What "spliced" wires?
Old 03-18-2013, 12:10 AM
Canada's Avatar
For your oil sensor go order this
http://www.improvedracing.com/oil-co...ine-p-196.html
Old 03-19-2013, 09:38 AM
joeyagls1's Avatar
Is it like hidden in the dash, I have to play with the buttons?
They are from speedhut gauges.
Also, the wires I found are for just for the lighting, they are red,black,white wires that have the ends cut where the wire is exposed, I just need to find a spot to put them to or connect. them.
Old 03-19-2013, 09:39 AM
joeyagls1's Avatar
Originally Posted by Canada
Damn another thing I will have to buy lol, looks good though thanks man.
joeyagls1's Avatar
Oh I got an 04 gto, I do not know if that would have it.
Old 03-19-2013, 05:33 PM
svede1212's Avatar
'04s don't have the CAN bus which the LS2 does with the harness. For oil pressure you need to install a sending unit. They are not all the same so I'd contact the manufacturer to get the right one.
Old 03-20-2013, 09:24 PM
joeyagls1's Avatar
I figured the newer gtos had the, oh well. Thanks man. Yes will figure out the right one ahead of time.
Old 03-20-2013, 09:53 PM
Alpha Male's Avatar
From what I recall, you replace the stock oil pressure sensor (aka sending unit) and replace it with one that has the plug or pins to connect to your gauge. 3feet of wiring sounds like too little, though.
I think you can go get some primary wire and extend the wire to the length you need.
Old 03-20-2013, 11:40 PM
gconnoyer's Avatar
No there is a temp gauge in the cluster....
As far as the red, white, black, read the instructions that came with the gauge.
I'm sure its Red- 12v switched, Black - Ground, White- probably will be wired to a variable voltage source (dimmer switch) so that you can dim the gauges with the cluster, radio, interior lighting
Old 03-21-2013, 09:07 AM
joeyagls1's Avatar
That sounds about right with the colors. I never got instructions, for how much I paid lol. I will try and hook it all up tonight and see some lights hopefully.
Old 03-21-2013, 05:45 PM
gconnoyer's Avatar
Should be easy.
Extend the black one and run it to a good ground.
Use a test light, and find a key on source and throw in an add-a-fuse for the red.
You'll have to call and see but I'd bet the white is for the dimmer (optional)
Old 03-21-2013, 07:04 PM
svede1212's Avatar
Use the power plug under the radio. It has switched power, dimmable lighting and ground lugs and it easy to hook up to with crimp-on female spades
Old 03-21-2013, 09:20 PM
joeyagls1's Avatar
all my gauges are in the pillar pod by above the steering wheel, I can only reach around the steering wheel and the fuse box area inside. But thanks for the info!!
Old 03-22-2013, 07:09 PM
gconnoyer's Avatar
So why not just extend the wires?
Quick Reply: I got some gauges for my pillar, but no direction.
