Clutch Cylinder
Unless there is a particular problem with the master in the car or you are modifying it in such a way to need something other than stock, the stock master cylinder doesn't need to be swapped out. Most aftermarket clutches that use a stock style slave cylinder will work just fine with a stock master.
