6-Piston Brembos
6-Piston Brembos
Well, I guess I have to be able to stop right? Since my brakes are shot right now I decided it was time to put the brackets I've had in my garage for 6 months to use. The calipers came yesterday and they are huge!
-Brembo 6-piston 17Z calipers
-Ferodo DS2500 pads
To be matched with the BMW 745i 13.7" cryo-treated and slotted rotors, I also ordered some Russel stainless lines which are backordered.
The only question is what color to do them in with an orange car and hyper silver wheels? I was thinking gloss black with orange flake, but I want to hear/see some other ideas.
-Ferodo DS2500 pads
Then either BOM or silver. The silver will get lost in the wheels and rotors which would be okay in my opinion, but I assume you want them to stand out a bit.
The Proxes rotors are only for 4-pistons in the front and a much smaller caliper. These 6-Pistons will look huge, which is what I need behind 19s.
I picked them up from Bohnman Customs (an LS1GTO sponsor), his last set. He now sells the 6-Piston CTSV Brembo brackets for $240. These actually have a larger piston area than the CTSV 6-pistons. I have done the math and with his 13.4" 4-piston CTSV rear kit and these Touareg front calipers the brake bias is within 5% of stock, leaning a bit towards rear bias.
And yes they use 13.7" BMW 745i rotors, which require hub rings. The CTSV Brembos require the rotor to be machined and opened up to the GTO hub diameter.
I've never seen that on a caliper before so it's going to be nice to have something custom. But here's almost exactly what you suggested lol
