Pontiac GTO 2004-2006 The Modern Goat
Loose Steering
Old 07-17-2013, 04:00 PM
Red2005Goat's Avatar
Default Loose Steering
Ive had a problem with my steering being loose for awhile now. I have a good amount of play in the wheel left and right. It just feels very sloppy and unresponsive. Definitely need to tighten it up. I have replaced the tie rod ends a few months back but that didnt really do much. Anybody else have this issue with loose/sloppy steering?
Old 07-18-2013, 09:40 AM
Rich-L79's Avatar
Did you replace the inner or outer tie rods?
Old 07-20-2013, 12:45 PM
big reg's Avatar
Try the BMR steering rack bushing. Stocker tends to wear out like every other pos bushing on these cars.
Old 07-22-2013, 07:49 AM
I replaced the outers about 3 months ago but not the inners.
Old 07-22-2013, 07:51 AM
Good call. Yeah it is unfortunate that at 63k pretty much every bushing has probably gone to ****
Old 07-22-2013, 03:23 PM
Rich-L79's Avatar
Check the rack bushing and the inner tie rods then. Might want to check the lower ball joints too. If you haven't replaced the radius rod bushings and strut mounts you should replace them even if they aren't directly related to your observed problem.
Quick Reply: Loose Steering
