header leak
Did you check the bolts and make sure they're tight? Sometime header bolts will loosen up over time.
I'd take a ride to Autozone and have them scan it for you or buy a scanner. They're pretty cheap on amazon and it's a good thing to have. I keep one in each of my vehicles.
If it's still leaking after that, the gasket could be bad. Get new ones from gm, they're much better than aftermarket and they are re-useable. While the headers are loose, check the flange with a straight edge to be sure it's not warped.
so i took a closer look with a flash light and see that the back left furthest header tube the gasket is cracked off and can feel exhaust coming out the top of it. How bad will this be if i need to drive it here and there before getting it taken care of?
would these gaskets work using pacesetter headers?
http://texas-speed.com/p-219-gm-ls1l...er-gasket.aspx
