04 GTO Issue
04 GTO Issue
Again this is not my car, I have another friend with a 04 GTO which I think is a "gremlin"! The problem is that 1. The port where you plug in a scanner doesnt work. 2. When the car was purchased, 3 relays were burnt out. 3. The gauge cluster goes haywire. When you press the gas, the tach jumps up and down as if your pressing the gas at idle.
I have been reading were their was a high failure rate for the gauge cluster on this model. We checked every single fuse, replace the pcm (because I thought it had a burnt out driver) and traced every ground to make sure everything had a good connection. The only weird thing I really noticed was when we removed the gauge cluster their was a stamp date on back of the cluster that said "02/11". To me that means it has been replaced before. I read of replacing the stepper motor that works with the gauge cluster, but I dont want to be just throwing parts at it !
I am all out of options here. By no means am I a mechanic, but I dont know what else to do except advise my friend to take it to the dealership because of the TSP. Any help would be appreciated!
