Pontiac GTO 2004-2006 The Modern Goat
Need help with suspension upgrade
Old 04-10-2014, 01:56 PM
Oneslowgo's Avatar
Default Need help with suspension upgrade
My question is what all should I replace and get to make my car hook at the track and also better on the street? I've read about adjustable shock and coil overs but still haven't got down to the best all around set up. Right now I am h/c/I/e and have no traction at all. I drive my car daily and want it set up for weekend track racing. Thanks in advance
Old 04-10-2014, 02:01 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
What kind of tires are you running or planning on running? Also does the car have an auto or manual transmission? Do you have any suspension parts currently installed on the vehicle?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 04-10-2014, 02:17 PM
Oneslowgo's Avatar
Right now I am running everything stock from factory and the tires I am running on street are 255 35 18 Vredestein Ultrac Sessanta and 275 18 m/t et street at the track. Auto 3200 stall
Old 04-10-2014, 02:31 PM
BMR Sales2's Avatar
With the kind of power you are making you will probably never get the 255 35 18 Vredestein Ultrac Sessanta to hook on the street. You should be able to get 275 18 m/t et street to hook on well prepped track but anything less will be tough just because there isn't much sidewall to them. As far as suspension goes I would really recommend looking into a set of drag bags and rear adjustable shocks. Both of these suspension mods will really help drive the tire into the ground which will improve traction and straight line performance.
BMR Drag bags (DB001)
Koni rear adjustable shocks (8041 1194SPORT)
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-10-2014, 02:43 PM
Oneslowgo's Avatar
Oh ok thank you very much.
BMR Sales2's Avatar
Not a problem, if there is anything else we can help you out with please let us know.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 04-10-2014, 07:23 PM
2QWK4RU 06 GOAT's Avatar
You need better tires, try a set of re11's if this is a street car... they will transform the way your car leaves.
On the track, you have the right tires, is wheel hop an issue?
Old 04-10-2014, 07:46 PM
ULTIMATEORANGESS's Avatar
i have to say tires are a must for these cars. mine wants to hop launching at idle lol.
Old 04-10-2014, 09:44 PM
Oneslowgo's Avatar
I guess I shouldn't jump the gun. I ran it with full exhaust and intake with the tires hooked well but I figured I would not hook once I did the heads/cam/intake so I guess I'll run it see how it goes then go from there
Old 04-11-2014, 06:19 AM
Dyno Junkie's Avatar
I assume you meant 265/40/18 Mickey Thompson.
Old 04-11-2014, 08:43 AM
slogoat's Avatar
Tires and Drag Bags. When I was at stock power, with just Nittos and the drag bags, I was able to pull a 1.79 60 ft and that's with a stick shift car.
Quick Reply: Need help with suspension upgrade
