LS2 to LQ9 swap
LS2 to LQ9 swap
Well long story short my brother in laws 2006 GTO developed a rod knock. He found an LQ9 with a 24x reluctor crank. My question is what else do i need for it to bolt on to the GTO.
I apologize for being so vague but would like to know what esle i would need for it to bolt on .
Thank you
Thank you
U will hve to change to a 58x reluctor wheel. They make a box to convert it but I heard it doesn't work well. I'm having to do the same thing. It's like $50 for the wheel and a machine shop will do it for a couple of hundred $. If the motor doesn't hve arp rod bolt I would change them and bearing to be safe
The motor we got is an LQ9 built to LS3 specs with ARP bolts on the crank and rods.
You need to drill and tap the block for the alternator bracket also. I have done the swap. Also some GTO's that were made in later 06 did come with a 58x reluctor wheel. Don't forget to plug up the hole in the block for the oil dipstick tube since the gto has it go directly in the pan. I only have 40 miles maybe on my LQ9 build but I am making some really serious power and haven't even sprayed it yet. I've had as low as 10.8x's and still dialing it all in. Have any questions on what works or what doesn't feel free to shoot me a pm.
The following users liked this post:
Pontiac Spazz (12-22-2019)
Use Hobart or Lincoln high quality welding rods for these purpose available at your local welding supply (be sure to get the expensive rods) as to not crack the block AND IS PERFECTLY SAFE.
The rite welding rods price is north of $15. per pound btw but all you need is one free sample to do the job.
Be sure the bolt to use is correct length as to not bottom out.
Else is best to weld oil dip stick hole plug in place cause in my case at first would pop rite out and oil headers.
Because otherwise, no they didn't.
