Which heads???
Which heads???
Alright, so it's time to get some heads. As of right now. I am running a Torquer v2 112lsa, Stock 241 heads, FAST 90, FRE 91mm tb, K&N, 36# FAST evo injectors, Kooks 1 7/8 lt's w/ 3in catless mids, 05-06 corsa touring. Now I have been looking at getting some prc heads. As of right now the car is sitting at 415 to the wheels. Looking to hit 460ish whp. What heads do you guys recommend??
I would personally save up for a good set of Trickflow 225cc heads. You really can beat the CNC heads and if you already have $1700ish in the budget just put it off a little longer and get the good stuff. Another thing to remember is even though the Trickflows are a great head along with others out there you will have to change your rockers as well. Something else to budget for. The CNC heads will definitely help you get to your power goal no doubt though. Check out the write up I have been doing on here. For all your parts and performance needs check out our site
www.hinsonmotorsports.com
https://ls1tech.com/forums/pontiac-g...otorports.html
