cam question
cam question
If i go with a http://www.tickperformance.com/tick-...r-ls2-engines/
Do i need the 3 bolt conversion? They told me i need an upgraded oil pump?
I will need upgraded Valvesprings and hardened pushrods
I actually own this camshaft just havent installed it yet along with ls6 stage 2.5 PRC heads.. You dont need the 3 bolt conversion thats only for LS3 engines as I was told from Tick themselves. You will definitely need a good double valvespring set up along with hardened pushrods. I would also recommend you get LS7 lifts while your at it.
I highly recommend at the very least a new LS2 timing chain(prefer the Katech C5R especially on a Polluter cam car that will need to shift at 7000rpm for that camshaft to perform optimally), a ported LS6 oil pump and you will need a cam swap bolt/gasket kit to swap the cam.
If you have a manual trans, you need at least 4.10 gears for this camshaft to perform optimally and 3.73's with a A4. If you have a A4 you need at least a 4000rpm stall for this camshaft to perform optimally.
