Wheel adapters and spacers
Has anyone has luck running wheel adapters to run corvette rims or other make rims? I am looking to get away from the 120mm pattern. Does anyone make longer wheel studs so I can run wider rims?
ARP studs are longer as the ones that fit really aren't for this car and usually need to be cut down. The fronts use EVOs and the rears use Corvette/Camaro studs ARP 100-7717 and 100-7708. Some run the 4 3/4" bolt pattern without issue as with careful tightening are only something like .65mm different. There were people making wheel adapters but I don't recall who.
