Pontiac GTO 2004-2006 The Modern Goat
3.91 gears...
Old 02-19-2015, 12:45 PM
LS1Goat2004's Avatar
Default 3.91 gears...
Does anyone know of a good site where I can get some 3.91's? Kinda confusing... searching for them I see them priced at anywhere from 100-150 all the way up to around 600. Doesn't make much sense. Also what brand would you suggest going with? Thanks in advance.
Old 02-19-2015, 12:53 PM
svede1212's Avatar
You aren't going to find any new that fits our rear end for $100. They are all around $450-600. gForce Engineering is a good place to start.
Old 02-19-2015, 02:27 PM
Jontall's Avatar
Do not buy Motive gears from Gforce because they will make noise. Andy (A_Vas) has OE Australian gears in stock (3.91 and 3.73). Post #13 and #17 here: http://www.ls1gto.com/forums/showthread.php?t=686545
Send him a PM there or call Complete Street Performance; they are a sponsor on ls1gto.com.
Old 02-19-2015, 06:19 PM
svede1212's Avatar
Good point although the setup is probably the most important thing. You can also get gears from Difftechnics in Australia.
Old 02-19-2015, 06:30 PM
2QWK4RU 06 GOAT's Avatar
I have oem gears, and the correct bearings and seals. I build these diffs on a regular basis. Pm me if I can help.
Afaik, the vendors mentioned above don't use all the same parts that I do.
Old 02-19-2015, 06:42 PM
The Motive gears are fairly quiet if set up correctly, there are other install issues with them.
Old 02-19-2015, 11:53 PM
Thanks for all of the responses guys. I will definitely check out some of those links/companies that make em. 3.91's for an A4 2004 isn't too much, is it?
Old 02-20-2015, 08:53 AM
Jontall's Avatar
I didn't realize you also sold gears and parts.
Old 02-20-2015, 09:18 AM
I do. I also rebuild/mod trutrac and oem lsd units. I've got 3 wavetrac builds this week alone, but they are sealed at the factory and there has been no need to touch them so far.
Old 02-20-2015, 02:17 PM
Jontall's Avatar
PM me a price on a rebuild with a Wavetrac and the turn-around time. Do I need to buy the Wavetrac from DSS? Do I need to supply a core? I have new gears sitting here.
Old 02-20-2015, 06:31 PM
ULTIMATEORANGESS's Avatar
Smile
its been awhile but last i checked gears were major expensive for these cars thats why i decided against it.
Old 02-20-2015, 10:51 PM
SIC GTO's Avatar
Same here. I wouldn't mind having 3.91's or even some 3.73's but the cost and after some things I read I decided to just stay stock.
Old 02-21-2015, 01:25 PM
Felix C's Avatar
For the gain 3.46 to 3.73 is 5% tq increase or 10% for 3.91 IIRC
Old 02-22-2015, 07:58 AM
george g's Avatar
Motive gears can be had for about $350 on ebay.
Old 02-23-2015, 08:20 PM
GotToGo's Avatar
You guys know anything about this site?
http://www.nationaldrivetrain.com/start.php
Old 02-24-2015, 01:26 PM
Bought from them twice, would never buy from again; I know that much.
What are you after?
Old 02-24-2015, 08:06 PM
bohnman's Avatar
Wavetrac and 3.91's in warm Cali headed to cold Chicago right Mike
Old 02-24-2015, 08:31 PM
Soon... very soon.
Old 02-24-2015, 08:41 PM
GotToGo's Avatar
What are you after?
Nothing. I ran across that site a while back but never used them. I always wondered if they were legit so this seemed like a good time to ask.
Old 02-26-2015, 12:34 PM
A_VAS's Avatar
I have Dana 3.91 and 3.73 on the shelf, FYI
they aren't cheap, but they aren't noisy either
Quick Reply: 3.91 gears...
