NEW Hinson Motorsports 800HP & 1100 HP Driveshafts and Engine Mounts
#82
#91
The final version of the mount will be black urethane. The blue was done for illustration purposes.
It is an interlocking stainless steel design that matches our engine mounts. The triangle in the center was for mock up purposes. The top and bottom sections are floating in the urethane to help dampen vibrations.
#93
Just purchased the Hinson motor mounts, 3/8th shorter for header clearance, did what they were suppose to do! I really like the feeling you get from them over oem. I recommend these to anyone who is in the market! Will purchase Trans mount from them when available!
Hinson will be my go to place for parts!
#94
#96
Thank you for the feedback. It is certainly welcome. be sure to keep an eye out for when it comes out and get you one.
#98
It adds a little extra hood clearance if you need it and on some cars it helps with header to steering shaft clearances. If your running an OTRCAI keep in mind you will have to adjust here as well for the lowering of the engine. It can be done but may require a longer coupler and some new adjusting. Thank you for the feedback BTW.
#99
Sounds great! My concern is height after driveline weight is added. The oem mounts compress quite a bit and thus is important to us because many of the current headers and turbo kits were built on a stock driveline. In my case, if it's any taller after install, I risk steering shaft interference because aps did shitty R&D in this area.
#100
Ah thanks!
I think I have kooks headers ( previous owner installed) and as far as I know no issues. I still don't have an intake yet but was considering the xaier intake ( I think that's the name)
I'm stoked about making some changes to this car, as of late I've become more concerned about getting the most out of existing power as opposed to just creating more power of an existing setup
