Pontiac GTO 2004-2006 The Modern Goat
05 goat cam
Old 04-12-2015, 03:13 PM
Slickgoat05's Avatar
Default 05 goat cam
About to order my cam...Torquer v3 with PRC .650"springs, 7.400" rod length. Car has longtubes, no cats, intake, tune. Anything else i should look at before purchase? Thanks.
Old 04-12-2015, 04:35 PM
ULTIMATEORANGESS's Avatar
Smile
gaskets,bolts,fluids.
Old 04-17-2015, 02:46 PM
SJFGTO's Avatar
Trunion kit is always a great idea. Not required, but its a great time to replace your water pump. The stock pumps have a high early failure rate. NAPA is a good source for a reliable replacement. Also, maybe a UDP if you are feeling feisty.
Old 04-18-2015, 12:38 PM
are udp's really worth the money? Ive read they can cause failures?
Old 04-18-2015, 05:31 PM
if youre adding a cam then id get them too.
with an auto your idle will need to be raised to keep charging in a safe range otherwise theres no need for concern.
Old 04-22-2015, 03:51 PM
SJFGTO's Avatar
No failures from a udp. 5 to 7 HP gain on a dyno.
Old 04-22-2015, 04:28 PM
i just went ahead and bought 1, cam goes in next wednesday. the wait is gunna suck lol
Quick Reply: 05 goat cam
