Pontiac GTO 2004-2006 The Modern Goat
Hinson Motorsports Short Throw Shifter for 04-06 GTO, and Transmission Mount Update
Old 02-15-2016, 10:27 AM
  #41
pitbull14218's Avatar
Originally Posted by ledzepp3
I just got my short throw put on my '06. It took longer than I expected, even after reading the instructions and seeing what it entailed, but it was definitely worth it. The shifter doesn't feel like stirring a jar of peanut butter anymore, and feels solid. Reverse is a little stubborn sometimes, but you guys did a kick *** job on the shifter.
Everything came off as instructed (with some cursing), all the new parts bolted on, and it works like a charm. Now I've got some motor and tranny mounts on the way too
How does the shifter feel?
I need to replace my stocker, its between the hinson and the mgw-p, i just need to figure out which would be better for me.
Old 02-15-2016, 11:30 AM
  #42
HINSON Motorsports's Avatar
Very precise and a lot of fun to drive with. Goes in and out of gear the way that it should with a sportier feel. You won't be disappointed.
Old 02-16-2016, 05:58 PM
  #43
ledzepp3's Avatar
Makes a nice metallic clunk and the amount of force feels just right. You'll have to get used to how much tighter together the gates are, but once you do, downshifting becomes a breeze compared to the stock shifter.
Old 02-18-2016, 10:15 AM
  #44
The metallic clunk you hear comes from the detente pin in the transmission. Just FYI, but thank you for the feedback. It is appreciated and glad to see your enjoying the product.
Old 02-18-2016, 03:15 PM
  #45
Thats what people modify for the anti-venom mod?
Do you recommend the mod or not needed with this shifter?
Old 02-19-2016, 09:16 AM
  #46
Precisely. I have not had anyone give us the feedback of feeling like it should be done. That doesn't mean that there aren't some out there that have done it at some point either before or after our shifter install. I have one in my 06 PBM GTO and would find it really hard to think that someone would find the need to do it, but that's simply a personal preference type thing.
Old 02-19-2016, 12:10 PM
  #47
Kingc8r's Avatar
Question about install, do you have to drop the teams or no? I thought someone told me you do have to for install?
Old 02-22-2016, 10:09 AM
  #48
You have to loosen the bolts on the trans brace to get the trans to drop far enough to get your hand on the front two bolts. This is a pretty common thing due to the way the GTO is designed.
Old 02-22-2016, 12:11 PM
  #49
Kingc8r's Avatar
Oh that's not as bad as it was made out to be. Good to know, I may start modding this slow *** stock GTO soon
Old 02-22-2016, 01:01 PM
  #50
s/c'd cav's Avatar
you can use a long ball allen wrench on the 2 front bolts and go through the 2 holes for the boot ring , and lower the crossmember enough
but lowering the trans crossmember does give you alot more room
Old 02-22-2016, 02:18 PM
  #51
Kingc8r's Avatar
If it's just the crossmember then I'm not sweating it. I also own an fbody so I know about having to deal with annoying **** to work on my car lol
Old 02-24-2016, 09:14 AM
  #52
Appreciate, the feedback.
It really is pretty easy. We have a lot of people do installs in their driveways and garages. I know I have done my fair share. Go for it, you wont regret the install.
Old 03-03-2016, 09:43 PM
  #53
Spring special
Or anyone want to do a group buy?
Old 12-22-2016, 09:31 AM
  #54
blackbyrd's Avatar
Anybody that installed the transmount feel it raised the tail shaft up by a lot?
I'm thinking it needs to be shimmed down a bit on mine, I feel like I'm getting some drive line shimmy due to the angle shift. Wanted to test it out before I installed the one piece drive shaft
Quick Reply: Hinson Motorsports Short Throw Shifter for 04-06 GTO, and Transmission Mount Update
