06 GTO dash lighting problems - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
Thread Tools Search this Thread
Old 06-14-2015, 02:09 PM   #1
ledzepp3's Avatar
Default 06 GTO dash lighting problems
hey everybody! Last night I swapped out the lights for my license plate in the rear and I went to turn my car on, and I noticed that my dash lights (the cluster lights) weren't turning on. So I did the usual thing for a GTO owner, I checked the body control module and I checked the fuse box underneath the dashboard on the left side.
I went to the store to replace the fuses in case they were blown, and that still hasn't fixed the issue. The gauges themselves work fine, and all of the other lighting in the car works fine, but the lighting in the gauge cluster does not work.
Help!
ledzepp3 is offline   Reply With Quote
Old 06-14-2015, 03:06 PM   #2
check the obvious...if dash lighting worked before and your fuses weren't blown..check all your connections and the insides.
Slickgoat05 is offline   Reply With Quote
Old 06-14-2015, 04:42 PM   #3
ledzepp3's Avatar
Quote:
Pulled the gauge cluster apart, pulled and checked every single fuse in the interior and engine bay fuse boxes, pulled the plugs on the light switch to the left of the steering wheel (which was looking good), and I even pulled a lot of the electronics out of the center console to see if anything was causing this. The only things I found that could have been causing this were the BCM wires which I fixed before... I'm puzzled honestly.
So far, everything else in the car is working 100% except these gauges... I really hope the lights themselves didn't die
Old 06-14-2015, 10:21 PM   #4
ledzepp3's Avatar
Tomorrow I'll be pulling apart the metal frame for the glove box mounts tomorrow to investigate if anything by the BCM is causing this, will update. Any other help is more than welcome!
Old 06-15-2015, 10:59 PM   #5
ledzepp3's Avatar
I found that it worked for a few seconds when the car was idling and my knee hit the fuse box when I sneezed, so I took another look at the fuses. The fuse for the gauge lights was in fact blown, but it jiggled back together when my knee whacked it before the engine shook it apart lol
So... solved!
Old 02-12-2017, 08:31 PM   #6
jaxcam02's Avatar
I would just knock it off there and use velcro or double sided tape in its place
jaxcam02 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Electronic/radio problem Canuck Stereo & Electronics 3 02-27-2017 08:30 AM
HELP!!! Fuse 7 blowing with keyless only door lock/unlock & engine off 2002 SS Camaro weeha Chevrolet Camaro 1967-2002 3 08-09-2016 10:16 AM
97 SS SLP cranks but won't start... any ideas? CamaroVsMustang LT1-LT4 Modifications 3 10-25-2015 09:18 PM
Car won't start. Gauge lights work but not the actual gauges... athornt2 General Maintenance & Repairs 9 09-03-2015 08:22 AM
Gauge cluster lights dont work FeedMeMustangs LT1-LT4 Modifications 5 03-05-2010 10:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
