Tech II reprogram vehicle speed
Can a TechII be used to change the speedometer readout after changing rear gear ratio? And if so how? I have access to a techII but haven't figured out how yet...LOL Thanks
Search around in here... I think it can change the speedometer too and it's cheaper than buying HPTuners (Tech 2 can't do it). http://www.ls1gto.com/forums/showthread.php?t=517098
"If you have 3.91 gears in your car you can change the speedometer beats to 7035 and your speedo will be accurate".
THANKS I'd skimmed that before....guess I've got some reading to do. :-)
