zl1 on a goat
zl1 on a goat
has anyone tried to put a zl1 or cts-v supercharger on a 04 gto if so how does it run an what all did you have to do for it to work also post some pictures thanks
As I said, unless that is complete, you are going to find a lot of things that you will need to purchase in order to make that work, such as the heat exchanger, injectors, accessories, fuel pump, etc. On top of that, you need a new hood since the blower sits too high. It will sit even higher with the adapter plates. Unless you just want to go the hillbilly route and cut a hole.
Has it been done? Yes. But I think you are going to find that a lot of parts are going to nickel and dime you to the point where you could have purchased a TVS unit designed to work with everything you already have.
http://www.ls1gto.com/forums/showthread.php?t=457256
Theres a thread on the Facebook page, a shop has made a pulley that puts the belt inline with the GTO accessories. I am just waiting for someone to confirm there is a lid that clears the stock hood.
