Pontiac GTO 2004-2006 The Modern Goat
What suspension are people running for lowering kits
Old 10-26-2016, 06:11 AM
BlackBettyGTO's Avatar
Default What suspension are people running for lowering kits
I have an 04 M6 lookingto lower and try to have a decent ride since the car is a street car, wondering what people are running! I'm looking for full kit options...
Old 10-26-2016, 02:50 PM
blackbyrd's Avatar
stay away from Eibach......do a search I have a thread detailing my experience.
spend them money and get lovells or Kings or go coilover
Old 10-26-2016, 06:00 PM
svede1212's Avatar
That about covers it. 20mm drop is the most you want without having damper issues, alignment issues or not leaving enough room for travel to the bump stops.
Old 10-27-2016, 09:53 PM
Dyno Junkie's Avatar
2005 HSV GTO on Eibach springs and Koni shocks.
Attached Thumbnails What suspension are people running for lowering kits-image.jpg
Old 10-27-2016, 09:58 PM
2001 Holden Monaro on Tein coilovers.
Rear shocks recently replaced with ViKing double adjustables.
Old 10-28-2016, 05:18 AM
2QWK4RU 06 GOAT's Avatar
What's the budget?
Old 10-28-2016, 09:15 AM
tom's2005gto's Avatar
2006 HSV on BC Racing all around
2005 GTO on BC Racing up front and QA1 out back
Old 10-28-2016, 10:44 AM
svede1212's Avatar
IMHO pictures of "stance" don't say much about ride and handling . Eibachs are mush and Kings are jarring. If road racing a stiff spring is OK but for all around a mid level like Lovells is better. Besides the harsh ride on the street too heavy of a spring can make the tires leave the ground on average crappy roads and you lose traction over one a little more compliant.
Old 10-28-2016, 03:58 PM
Certainly wouldn't call Eibach's mushy, soft and comfortable yes.
I had the Eibach and Koni combination on our previous HSV GTO, liked the ride quality that much I fitted the same set up to friends HSV GTO in the picture.
This car rides very smoothly on country roads and on the track has gone 1.72 in the 60' on drag radials.
Old 10-29-2016, 04:16 AM
Since you mention King, they have the most choices for us. In oem soft to all out racing. They also have many ride heights available.
Coilover is still the way to go if possible imo.
Old 11-07-2016, 03:08 PM
blackbyrd's Avatar
^ I actually think that is the route i am going to go after christmas. After my run in with eibach. originally I thought since its my daily i didnt want to put that kind of money into springs and shocks as I wasnt after the performance enough to justify higher cost of coilovers. Now that I have spent some time under the car and recognize some of the additional things that need to be replaced when installing these items, by the time you buy some better springs and shocks/struts and replacing the bearings for the fronts you could have purchased the coilovers especially if you were going with Koni's.
Old 11-07-2016, 06:00 PM
svede1212's Avatar
IMHO the only big advantage with coil overs is adjustablity. I don't know many people that continually adjust them but just pick a height and went with it. Pretty much the same thing you do with regular springs. 20mm leaves enough travel so you don't compromise ride yet handles better than stock height. Coil over does sound race but by definition the fronts are "coil over strut" from the factory. No biggie one way or the other though.
Old 11-09-2016, 10:13 AM
blackbyrd's Avatar
most dont realistically i tend to swap wheels every so often and I like to manage fender gap when I do. though I didnt realize until after reading an install review the rears really arent coilovers.
I agree the only selling point is adjust-ability and if you arent fiddling with that regularly its kind of useless. for my taste though if the cost is relatively the same why not have the adjustment factor though Koni's give you the dampener/rebound control dont they?
Old 11-09-2016, 12:30 PM
svede1212's Avatar
I got Konis way back when there wasn't much available at all outside of OEM or Monroe and they do adjust. Frankly I leave them on full soft all the time except the times I dragged the car. At that setting it is still stiffer than stock and with Lovells springs makes it firm but comfortable. They've held up great for about 9-10 years now.
Old 11-09-2016, 01:09 PM
blackbyrd's Avatar
I recently put some KYB excel g's on the rear of the car when I put the eibachs on and I have no complaints on them, but I think i jumped the gun on making the decision as I wanted to do it while I had the time (had a kid due in April) so in hind sight I think I would have rather spent the money to do a coil over setup or go Koni but sticker shock kept me out of doing them for some reason. Sad part is janurary of that same year I bought a set of ridetech level 2 coilovers for my firebird.
Old 11-10-2016, 09:55 PM
The thing with many coilover systems is they carry much more sophisticated valving, capacity and many have gone to a digressive profile which helps with keeping car on the road and ride is improved over bumps.
The off the shelf shock won't have this level of engineering. You might keep this in mind for future decision making.
Old 11-11-2016, 01:42 PM
blackbyrd's Avatar
^ valid points I hadnt considered 2qwk
Quick Reply: What suspension are people running for lowering kits
