04 GTO problems - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
04 GTO problems
Thread Tools Search this Thread
Old 11-30-2016, 07:04 PM   #1
Chris Licwinko's Avatar
Default 04 GTO problems
OK, I've read alot of different post on here as a guest, before signing on, I have a '04 A4 that I bought sight unseen on the internet, good price, but not as I thought. It had long tubes, no cats, SLP loudmouth, K&N CAI, no tune, melted O2 wires. I removed the longtubes, replaced with JBA shorties, JBA high flow cats, left the SLP anf K&N, did wires, plugs, O2's,Intake gaskets, smoked intake, no leaks, fuel pressure 58 psi at idle, driving car at 55-65 lt fuel trims are @18, around 80 lt fuel trims are @8, stft are varing between +3, -3, randomly throws P0171,P0174 codes, tried different MAF, no change. I had to put in O2 sensor spacers in the rear sensors to get it barely thru inspection (voltage @.120), engine light came on during exit, Also traction control randomly turns itself off, usually after a long decell, Does it need a tune? Or what to look at next?
Chris Licwinko is offline   Reply With Quote
Old 12-01-2016, 02:34 PM   #2
dw456post's Avatar
When you say fuel trims, do you mean afr reading from the wideband? You should probably turn off the rear o2's with the high flow cats. Sounds like you need a good tuner to tune it up. If you are saying that the wideband is reading 18 at 60mph, that is really lean. 8 is really rich.
dw456post is offline   Reply With Quote
Old 12-01-2016, 03:52 PM   #3
I'm going off my Actron scanner, viewing the data stream while driving
Old 12-01-2016, 07:14 PM   #4
dw456post's Avatar
I'm not familiar with Actron
Old 12-02-2016, 01:17 PM   #5
MuhThugga's Avatar
Check your fuel pressure under load.
MuhThugga is offline   Reply With Quote
Old 12-09-2016, 12:45 PM   #6
Buzzmanb12's Avatar
Also check the fuel pump relay. Mine did the same thing some 10 years ago and it was the in-tank fuel pump, worked fine at idle but started "Laying down" under load. It caused the relay to go bad as well.
Buzzmanb12 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Installed Longtubes, midpipes, catback, intake; How do these gains stack up? ChrisCarey Gen 5 Camaro External Bolt-On Tech 11 09-04-2013 12:17 AM
getting O2 codes after shorty header install (P0140,P0174) SickZ28 Generation III External Engine 1 06-19-2012 04:11 PM
Chasing Gremlins oh my! (DTC P0171,P0174,P0300,P0440,P1416) Ouija General Maintenance & Repairs 4 05-03-2009 01:07 PM
Anyone Running 5.3L Heads on LS1 ??? AwesomeGTO Pontiac GTO 2004-2006 3 01-30-2007 11:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
