Pontiac GTO 2004-2006 The Modern Goat
TH400/TH350 with stock shifter?
Old 12-19-2016, 07:54 AM
chopperloco's Avatar
Default TH400/TH350 with stock shifter?
Has anyone managed to connect a stock auto shifter with a turbo 400 or turbo 350?
Thanks
Dom
Old 12-24-2016, 10:56 AM
dw456post's Avatar
I used a stock shifter with a 4L80. Should be the same as a 400---Except the D on the shift selector will be 3, and 3 will be 2, and 2 will be 1.
Old 12-26-2016, 08:25 AM
Thanks!
Old 04-05-2017, 03:35 PM
Canada's Avatar
Why not use a B&M? Chris from GForcce makes a plate to mount it to the car and then mount the shifters on it. Then you just drill a hole to run the cable down. YOu'll want a 3' cable bc i had a 4' that came stock and it burnt a hole.
Quick Reply: TH400/TH350 with stock shifter?
