Vortech's GTO supercharger is available!
Vortech Engineering, LLC has introduced a new supercharging system for the 2004 5.7L Pontiac GTO with an automatic transmission.**
The addition of the V-2 SQ S-Trim supercharger will increase horsepower from 350 to 481 and torque from 365 lb./ft. to 435 lb./ft. at 7-8 psig at the flywheel.***
The system includes an integrated dual-pass air/water charge cooling configuration, which features a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as billet aluminum mounting bracket, fuel system upgrade including replacement injectors, supercharger oil feed and drain, compressor bypass valve and all required fasteners are included. The installation allows retention of all factory accessories including A/C and power steering. This system is available in satin or polished finish. The V-2 supercharger is covered by a three-year limited warranty.
*Legal in California only for racing vehicles which may never be used upon a highway.**6-Speed system to be released by the end of September, 2004.***Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements.
Our pricing is -
Part # 4GJ218-010SQ 2004 5.7 Pontiac GTO - (satin) $5199.99
Part # 4GJ218-018SQ 2004 5.7 Pontiac GTO (polished) $5459.99
Call or e-mail for any additional discounts that we may have!
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
I sure hope you can answer this question.
I am putting a 2000 F body LS1 in my 69 Camaro. I am using the stock LS1 F body accesory brackets.
I know VERY LITTLE about the GTO configuation.
Would you know if the brackets on the GTO LS1/2 are based upon the F body brackets? If so, my guess is I could easily modify one of these kits to fit my Camaro.
Any more pics of it installed?
Originally Posted by tbyrne
I don't believe those brackets are based on an f-body. It might be a little trail/error to make that work in the '69.
