Pontiac GTO 2004-2006 The Modern Goat
Solid axle conversion?
Old 08-27-2006, 09:19 PM
Dbluegoat's Avatar
The IRS can go well into the 10's......
I've been beating mine and its still ticking......
145 passes, 2yrs, you see my times in the sig.......no upgraded parts, no breakage.
I plan on going low 10's on it and maybe just once run a 9.9x
The solid axle conversion is def. not something I would do, our cars are too nice. You want to run big 9's buy a used fbody and spend less
Old 08-28-2006, 10:58 AM
whatsaholden's Avatar
+1
for the cost of a stock gto, you can build an fbody that runs 10's.. why wouldnt you? i mean, if you MUST have sra..
Old 08-28-2006, 10:14 PM
BlueSix's Avatar
I've decided i actually like the rear in the car, they seem to hold together a lot better than an f body 10 bolt after you eliminate the wheel hop.
Old 08-28-2006, 10:54 PM
yay! +1 for irs!!
Old 08-29-2006, 06:56 PM
Pathological Modifier
Ryan K's Avatar
You left out the only important satement.. In an Automatic car. My F-body was runing 10's on the factory 10 bolt, but only cause its an auto car. These break "almost" as easily as a 10 bolt in a manual car. M6 and a solid clutch and ther rear end goes boom...
Ryan K.
Old 08-29-2006, 08:29 PM
thats why you dont drag the m6. the auto is faster anyway.
Old 08-30-2006, 10:31 PM
DadsYellowGoat's Avatar
Just something to think about 2 of the fastest GTO's on the boards Kenny's Cartex tuned 9.7 @140 and Brent's Cartex tuned 10.3 @ 133 both had almost stock IRS in them. While everyones bashes them how many have actually broke one. Putting a straight axle is no simple swap as Kenny and anyone else following has come to realize. Since replacing the IRS his car has not been back in the 9's. While I am certain he will get the bugs worked out maybe the IRS was not as much a problem as everyone seems to think.
Old 08-30-2006, 11:03 PM
+2 irs
Old 07-26-2016, 10:47 PM
95z286.0ls's Avatar
Default sra
then why is it so hard to find wheels for these cars no one makes them unless you special order them which i think is a bunch BS.
Old 07-27-2016, 07:57 AM
svede1212's Avatar
Seriously? Maybe 20,000 left and a fraction of those that will buy them.
Old 08-02-2016, 07:51 PM
Nmbr1GMfan's Avatar
10 year thread bump!
Quick Reply: Solid axle conversion?
