Pontiac GTO 2004-2006 The Modern Goat
Does anyone know any tricks I can pull to beat an 03 vette with my 04 gto?
Old 04-14-2005, 04:58 PM
skelly's Avatar
Question Does anyone know any tricks I can pull to beat an 03 vette with my 04 gto?
Hey all,
This is my first posting here. I bought an '04 GTO in Oct-04. Quicksilver, 6-speed. I'm absolutely loving it.
I'm racing a buddy on the quarter mile track at Joliet Speedway this coming saturday. He has an '03 vette, 6-speed. Now, this is just a friendly race and I'm pretty sure he'll beat me, what with the weight and traction advantage of the corvette, and I'm more or less cool with that, but part of me still wants to put up a good fight.
Back when I was a teen we used to do little tricks like pull the air cleaner off our 70's camaros to make them breathe better. I read in one of the car mags that they were able to get a stock 04 GTO to run a faster quarter mile by deflating the rear tires a bit for better traction.
Having said all of this, does anyone know of any other little tricks I can pull on my bone-stock gto to get an edge on a bone-stock 03 vette? Pull out the spare tire?
Also - is it any danger to my engine if I run racing gas or octane boost?
Old 04-14-2005, 05:19 PM
YlwGTO4m3's Avatar
Deflate rear tires a few pounds will help
Taking out spare tire and any extra weight, aftermarket subs...etc
fill gas tank to only about an 1/8 of tank max
If you're not worried about your tranny then power shift that bitch
keep your engine cool by turning on the fan and opening the windows in the line for the strip, if you're at a track
Do not do a burn out, go around the water if they have it
the stock 245's are a *****, you gotta use a lot of clutch to get a good 60ft time.
bottom line he is lighter and has bigger tires and should beat you by about .5 seconds or so, driver dependent of course.
Practice.
good luck
Old 04-14-2005, 06:00 PM
Chivo's Avatar
DO NOT run racing gas or octance. Ran that stuff and ran 14.4 in my goat. Went back the next week without the gas and ran 13.3. DONT DO IT
Old 04-14-2005, 06:48 PM
Matt SS's Avatar
Definatly take out any extra weight. But the bottom line is he is lighter, more areodynamic, and has wider tires. You might put up a good fight.
Old 04-14-2005, 07:17 PM
burbman's Avatar
If he's in a 6 speed too, you might have a chance, as shifting can be the great equalizer. Maybe you could put your spare, and any other weight you can find into his car to even things up a bit.
Old 04-14-2005, 07:19 PM
WAHUSKER's Avatar
Well if it means that much to you, for 1 run you could disconnect the air tube from the filter box. "They say" that a cold air intake box adds 20hp to these GTOs, so that would make a noticeable difference. But I'd stop at the end of the track & hook it right back up. You remember how that would destroy the rings on a motor pretty quick.....the air didn't get any cleaner since the 70s!
Old 04-14-2005, 09:36 PM
BlueSix's Avatar
Drop the rear tires to 25 psi, up the fronts to 45 psi. Pull out all the excess weight you can, only have about 1/8 tank of gas. Drive around the water box. Do a burnout to clean off the tires. I'm still experimenting with how much is too much, but i hooked better after a 10 second burnout than after a 3 second one. Slip the clutch at 3000. Shift at 5900-6000 and never take your foot off the gas.
Old 04-15-2005, 06:41 AM
V-seriesTech's Avatar
Originally Posted by skelly
Hey all,
You can try nitrous
If thats too drastic, try the pit manuver.
Old 04-15-2005, 11:42 AM
skelly's Avatar
Thanks y'all. Sounds good. I'll post the results and possibly an mpeg if I don't get totally smoked.
Old 04-15-2005, 02:33 PM
Snafu's Avatar
Remove your driver's side headlight...seriously.
The openings that funnel the air to the filter box come from behind the headlight, when you remove it, you get a ram-air "effect". It's a trick the Aussies showed us...never tried it personally, but it's said to be good for some time/power.
Do not remove the air tube...from idle to WOT, you'll be all messed up. The MAF needs to read something to adjust your fuel tables...if you bypass it, it can get pretty screwy.
Old 04-15-2005, 02:49 PM
SDB
SDB's Avatar
put on a wet kit and jet it to 100 shot, change plugs to TR6's gapped at .038, use 93 octane, shift nie and easy, go aroudn the vette at mid track...
Old 04-15-2005, 03:32 PM
Moderator
xp3nd4bl3's Avatar
Two words:
Sneaky Pete!
OR:
Red Light
Old 04-15-2005, 04:28 PM
skelly's Avatar
It's going to be hard to look all nonchallant/"I don't give a **** if I win" after I pull the spare tire, remove a headlight, flattern my tires and drive around the wet-spot, and have a pre-race colon-flush to drop weight.
However, it's mostly great (sounding) advice and I'll probably use all of it.
Old 04-15-2005, 05:19 PM
Rob
Rob's Avatar
I got the best short times when stock running 30psi, driving around the water box, and just spinning the tires by nailing it in first gear...no burnout. Bring rpm up to 3000 or so and release the clutch fast, no dumping, while doing the same on the accelerator. This technique got a few 1.9x short times.
This was with 1/2 tank of gas and a racing weight of 3960 with me in it. Got it down to 13.2x, probably could have done a little better with more practice. Started doing mods after that
Old 04-15-2005, 09:33 PM
2Cool's Avatar
Let the air out of the rear tires...
His rear tires...
Heh...
Old 04-15-2005, 11:12 PM
maximental's Avatar
Default You could
Pull the valves out of the valve stems on his tires, forcing him to forfeit until he finds some replacements. j/k
I heard about the taking out the headlight thing from a guy at work, and then a couple of days later, someone else told me about it, so apparently there is something to it.
I was going to go dragracing tonight, but got rained out.
I hope you have better luck.
Maximental
Old 04-16-2005, 05:25 AM
Tom@SpeedInc's Avatar
Your gonna have to launch at 4000 and powershift at 5200-5400rpm. By powershift I mean wide open throttle and shift with your foot to the floor, if you shift any higher then 5400 you will go over 6200+rpm in the next gear, may hit the rev limiter and slow you down. practice powershifting. Be carefull not to miss 3rd gear! I used to aim for 5th gear till I got the ripshift
You may want to go to speed inc. in schamburg and pic up their GTO cold air induction, its been known to add 15rwhp.
Take out the fuel tank guard, remove all the clips from the middle trim pieace in the trunk. And take the 18mm (?) bolts out from the bottom and 13mm bolts from the top and you save 25-30lbs. Removing spare tire and jack will add another 15lbs weight loss.
Old 04-16-2005, 05:26 AM
In order to remove any front headlight from the GTO you have to remove the bumper cover.
Old 04-16-2005, 05:33 AM
You can run unleaded racing fuel, the street just before rt 66 on the north side of the track you go down that road their a road pilot gas station there that sells 100 unleaded, don't buy their 110 gas its leaded
octane booster does jack ****.
ps, make a few passes before you race, it took me about 6-7 runs to get a better time in the GTO. A buddy of mine took estimated 45 passes till he could get low 13s.
Old 04-16-2005, 07:16 PM
Moderator
xp3nd4bl3's Avatar
Race gas on a stock GTO probably won't do anything for you.
I also don't think short-shifting at 5200 RPMs is very sound advice. You'd be giving up a bunch of power.
Quick Reply: Does anyone know any tricks I can pull to beat an 03 vette with my 04 gto?
