broken rears /axles - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
broken rears /axles
Thread Tools Search this Thread
Old 04-17-2005, 09:26 AM   #1
Default broken rears /axles
Are you guys having any problems with breaking differentials, the CTS V seems to have this issue. And axles.
70GTO is offline   Reply With Quote
Old 04-17-2005, 11:39 AM   #2
GMCVT's Avatar
Might want to head over to ls1gto.com for more input but the axles seem to be the second weakest link in the drivetrain. The primary in the driveshaft. BMR Fabrication has been pushing there GTO to its limits and has an interesting bit of info on it on there website.
GMCVT is offline   Reply With Quote
Old 04-18-2005, 01:19 AM   #3
BlueSix's Avatar
BMR doesn't have a single stock piece in their driveline anymore, at least not that i can think of. But they did push the limits. After the axle's and driveshaft, what goes next?
BlueSix is offline   Reply With Quote
Old 04-18-2005, 01:26 AM   #4
Quote:
Axle stubs in the diff went next after axle shafts.
GTO_Scott is offline   Reply With Quote
Old 04-19-2005, 10:54 AM   #5
So you guys are breaking components but the diff is staying intact?
Old 04-19-2005, 01:11 PM   #6
JS
JS's Avatar
But when,I mean will a 12.50 A4 GTO break this stuff...
JS is offline   Reply With Quote
Old 04-19-2005, 01:51 PM   #7
CSiJason's Avatar
I've read a number of people with STS LS1 GTO's with A4's running in the 11's on stock drivetrain. I'd agree, the weak link is the drive shaft itself.
CSiJason is offline   Reply With Quote
Old 04-19-2005, 02:18 PM   #8
Rob
Rob's Avatar
Quick question, how many has anybody heard of breaking?
While BMR makes great stuff, they are also marketing the stuff they sell by saying stuff is weak. How many failures have their been in Australia? Here?
Weak links are the clutch and A4's. That is what you hear going first. Then the posi goes. Where are all the breakages from the hard parts?
There are quite a few 11 second GTO's still running the stock driveline and no failures. Just something to think about.
Rob is offline   Reply With Quote
Old 04-19-2005, 05:40 PM   #9
CSiJason's Avatar
I cant say I follow Aussie forums to hear about any problems.
I'm not sure that a handfull of people who make a few dozen passes in the 11's can say that the stock stuff is bulletproof or not. Heck, in my Honda I ran dozens of runs from low 13's to basicly high 11's on slicks over the period of several years on the stock CV axles. It took several years for one of the stock ones to fail and the other never did. However I know people who barely ran more than stock power and broke them more than once.
Old 04-20-2005, 10:35 PM   #10
Doc GTO's Avatar
Quote:
Most likely not while you own the car!
Doc GTO is offline   Reply With Quote
Old 04-21-2005, 09:49 AM   #11
I've been following the GTO and Cobra IRS issues for awhile....Bottom line, be smart. If the car wheelhops even a touch, get out of it. You would be surprised how many people stay in it when the car starts to get wheel hop....stupid....
automatics on decent tires generally are fine....
Kenny H is offline   Reply With Quote
Old 04-21-2005, 09:50 AM   #12
Quote:
An 11 second A4 GTO will have tranny problems first IMO.
Old 04-21-2005, 07:33 PM   #13
Thanxs for the feed back, I was wonderig if the cts v would ever come automatic, looks like that would just be another weak point. Since IRS is here to stay, it can only get better if the manufacturers would step up and fix this problem in the engineering stages.
Related Topics
Thread Thread Starter Forum Replies Last Post
Axle Bearing Job, found 0-ring? trailshredder Gears & Axles 4 07-01-2016 03:15 PM
Do I need the heat shield over the axle? hlaalu Generation III External Engine 2 07-05-2011 09:25 PM
Driveshaft Shop Axle LS2 6sp Pontiac GTO 2004-2006 3 10-22-2010 04:04 PM
solid rear axle 1_fast_gto Pontiac GTO 2004-2006 1 03-27-2008 12:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
