IRS on GTO
Re: IRS on GTO
It's a semi trailing arm (old out dated) set up.
It works alright but would be nice if it was double wishbone.
The camber and toe in/out changes as the suspension moves around. This is controlled to a degree by some toe controll links.
You will find for drag racing it soaks up some 60' time and for normal road use it will wear the inside edges of your tyres.
