Pontiac GTO 2004-2006 The Modern Goat
L92/L76 Swap Results Soon
Old 06-06-2007, 12:43 PM
8ByGoat's Avatar
Default L92/L76 Swap Results Updated!!
My 05 A4 GTO is at Tri Star Performance right now getting the following:
Touched up L92 heads with double spring package
Ported L76 assembly with ported TB
Cam swap
UD pulley
Kooks 1 3/4 with catted mid pipes
Spintech Catback
K&N CAI
3500 stall
Trans cooler
Shift Kit
NGK Plugs
Fluid change to Amsoil
Dyno Tune
Car baselined at (I think) 318 rwhp and 330 rwtq.
Old 06-08-2007, 09:28 AM
04goatman's Avatar
Let Me Know What The Rhp Is After Mods. Also What Ur Mpg In City Is Under Normal Driving, I'm Curious I Had Similiar Mods Done Except No Cylinder Head, Ud Pulley,shift Kit.
Old 06-09-2007, 11:20 AM
KrautBurner's Avatar
what's your cam specs?
I'm seriously looking into this swap too,
my main concern is how it will do with my cam (any clearance issues?)
Old 06-09-2007, 07:49 PM
8ByGoat's Avatar
Went out there today. Still waiting on the heads to come back from the machine shop. Will be next Saturday.
Don't know exactly what the cam specs are-all I know is not over .600 lift.
Old 06-10-2007, 05:36 PM
Blown_Red_97z's Avatar
I am going to guess around 460 rwhp because of the A4 and stall. Otherwise I would say like 480 rwhp if it was a 6 speed. Either way the L92/L76 combo is awesome.
Old 06-10-2007, 08:53 PM
that sounds pretty high....
(altho the stock numbers sound pretty low)
a gain of 145rwhp???
I would guess 80-100 rwhp gain (but I'm pretty new at this stuff)
Old 06-10-2007, 09:07 PM
yea I was kind of judging from the GTO board, the M6 made 415 rwhp with just the milled heads, intake, LT's, CAI, and UDP. Now with a modest cam, that same setup did 480 rwhp on an M6. Hence why I took away about 20 rwhp for the stall and auto, plus he is getting a little touch up work on the heads and intake..... but at any rate, its going to be quick! I really want the L92/L76 package right now.
Old 06-11-2007, 09:16 AM
8ByGoat's Avatar
It's the same shop that did the 480 car. That car did NOT have a ported TB or intake. In addition Robert will be doing some work on the heads.
The low baseline #'s are attributed to the fact I drove the car an hour to get there and it was then strapped to the dyno so in actuality a little higher.
We are hoping for 475rwhp.
Old 06-11-2007, 12:16 PM
kerryt1's Avatar
if you build it up on GMperformanceparts.com, the dyno simulator shows 475 BHP or so, with the ASA cam. With a different cam and factoring in drivetrain losses, my [uneducated] guess is 440-450 to the wheels after tuning.
Old 06-12-2007, 04:09 PM
8ByGoat's Avatar
Heads are done from the machine shop side.
Hand tooling tomorrow.
Old 06-13-2007, 02:36 PM
offaxis's Avatar
I will toss out a guess of 445rwhp ofcourse without a cam specs Im just tosing a number out there.
Old 06-14-2007, 12:47 AM
Buff's Avatar
i'm a rookie to this L92/L76 thing. What is so good about each???
Old 06-14-2007, 08:52 AM
8ByGoat's Avatar
The results for the $$$$$$$.
Old 06-14-2007, 09:52 AM
LOL, how can you be a rookie, you already have the package! Basically its a great heads and intake set for the money, and it produces great results on the LS2. I am so interested because first, it will look stock under the hood and second, well its just a damn good value
Old 06-18-2007, 01:52 PM
8ByGoat's Avatar
Well got the car back Saturday and it is absolutely incredible.
I can't tell you what the true numbers are because I don't have a dyno sheet. Robert didn't want to give me one because they couldn't get the converter to lock up and he didn't want me to worry because of the numbers. I will tell you he did say that it dynoed higher than a 07 ZO6 (which dynoed about 440rwhp). Rob speculated that it should be around 470rwhp.
Old 06-18-2007, 09:33 PM
sweetness's Avatar
Those are damn good numbers.... now spray that bitch!!
Old 06-19-2007, 02:25 AM
Buff's Avatar
i take it by that answer it is ls7 heads and intake manifold
Old 06-23-2007, 08:11 PM
8ByGoat's Avatar
Went back today to try and get the converter to lock. Still running unlocked but with a little more tuning we got to 451rwhp and 403rwtq which we think is pretty good. HpTuners really needs to get this issue resolved.
I will see if I can get Rob to post the dyno sheet.
More to come in a week or two.
Old 06-25-2007, 02:35 PM
8ByGoat's Avatar
Dyno sheet attached.
Attached Thumbnails L92/L76 Swap Results Soon-malcom-l92.jpg
Old 06-26-2007, 12:39 AM
al rocha's Avatar
I am very impressed with your setup.
I better start saving my pennies.
Congrats.....
AL
Quick Reply: L92/L76 Swap Results Soon
