Pontiac GTO 2004-2006 The Modern Goat
Stock GTO rim sizes.
Old 08-31-2007, 01:51 PM
Pntbll309's Avatar
Default Stock GTO rim sizes.
I may be purchasing a set of 2005 GTO rims from a guy, the question I have is what size are the rims? They are the Factory 5 spoke 18's. They currently have 245's on them. I want a 275 if I were to go with an 18'' wheel. Does anybody know the width of the stock 18''s and if they can handle a 275, and is the lug pattern the same as the f-bodies?
Thanks in advance.
Old 08-31-2007, 02:39 PM
woffman5's Avatar
Thanks in advance.
8" wide wheel. No, they are not the same bolt pattern. The GTO has a 5x120mm pattern. 275 will fit, as I have them on mine, but you don't get as good of a contact patch as you would witha 9" wide wheel.
Old 08-31-2007, 03:32 PM
tha joker's Avatar
like wolf says alot of 275's will fit the rims you have...
Old 08-31-2007, 07:19 PM
kyemt's Avatar
Default tire
yea but will teh 275 fit under teh fender well
Old 09-01-2007, 02:08 AM
Pntbll309's Avatar
are the 17's any different? I can get a good deal on them but if they dont fit my F body I dont want them.
Old 09-01-2007, 02:35 AM
KrautBurner's Avatar
mine do
Old 09-01-2007, 08:18 AM
kyemt's Avatar
Default 275's
hey kaurt burner do u have stock rims? and do u experience any rub, and what size 17 r u running? 275/40/17 or 275/45/17 ?????
Old 09-01-2007, 08:47 AM
Pntbll309's Avatar
do they fit f bodies?
Quick Reply: Stock GTO rim sizes.
