Pontiac GTO 2004-2006 The Modern Goat
New Shifter Setup
Old 12-03-2007, 12:34 AM
BAADGOAT's Avatar
Default New Shifter Setup
A friend had a short stick on his '99z28 (which was a SLP I believe) and he was getting rid of it as he bought a UMI so a friend cut a 1 3/4" out of it welded it back up and threw a Hurst Ball on it. Actually feels really good, I would say its comparible to a Lou's SS.
Attached Thumbnails New Shifter Setup-dsc00451.jpg   New Shifter Setup-dsc00461.jpg
Old 12-03-2007, 12:39 AM
flybye's Avatar
hmmm, thats different...i have heard of the pro 50 or maybe it was an SLP? from f-bodies fitting the GTO with a little modification. figure out which one it actually is, i would like to know.
btw, i think it would look better if you brought the boot up higher on the rod
Old 12-03-2007, 12:43 AM
BAADGOAT's Avatar
The was a SLP short stick before the we modified it...
Old 12-03-2007, 12:47 AM
flybye's Avatar
so is it a new SHIFTER or just a new shifter rod?
i have the stock shifter in my car but with a lou's short stick installed
Old 12-03-2007, 12:49 AM
BAADGOAT's Avatar
Its just the stick, bolted it to my stock "shifter."
Old 12-03-2007, 12:57 AM
flybye's Avatar
Originally Posted by BAADGOAT
Its just the stick, I looked up the SLP stick and it looks just like my stick so I believe its SLP, but its still the stock shifter.
hmmm.. well i didnt know it would attach to the stock shifter. it pretty much looks the same height as the stocker just threaded. if so i would look into getting a LSS like myself if you dont ming or like the stock throw but ant to impove it a bit. not only is it shorter but is angled towards you and is available to fit the stock **** or an aftermarket one
Old 12-03-2007, 05:18 AM
Rob
Rob's Avatar
Looks like an old MBA ****. Too bad they are not in business anymore, they made great stuff.
Quick Reply: New Shifter Setup
