Pontiac GTO 2004-2006 The Modern Goat
Need GTO starter info quick...
Old 03-04-2008, 02:29 PM
Durney's Avatar
Default Need GTO starter info quick...
Does anyone have a pic of a GTO LS2 starter???? I understand the nosecone is smaller and the bolt holes are slightly offset to another (that parts I think might be BS because the LS2 blocks should be all the same)
thanks!
Old 03-06-2008, 12:31 AM
mrtosh's Avatar
IIRC the nose cone is a bit small and the holes are offset a little. I did a cam change on a buddy's '06 GTO and had to drop the starter, it's been a while though. Check on ls1gto.com just to be sure.
Old 03-11-2008, 11:32 PM
rcsfastmonte's Avatar
yes they are diffrent
Quick Reply: Need GTO starter info quick...
