Gto Stock 1/4 Mile Times Are?
#81
new style gto 1/4 times
I was looking at these espesially the 04 gtos because the prices are coming down but i would hope they would be a little faster.....my all steel 55 chevy bel air went 13.40 with a stock 5.3 out of a truck and a carb bigger car less cubes no cam what happened to progress how come all that gm comes out with is so heavy!!! can the corvette engineers please work their magic on the rest of the fleet?
#82
The difference in the WHOLE CAR between an old Bel Aire and the goat is light years and don't forget 25-30 MPG . What did that pig of a Chevy get? The goat is primarily a GT car that happens to run a pretty quick 1/4. You're also comparing a modded car to a stock one. It takes very little to put a LS1 goat into the mid to upper 12s and ride in comfort. An independent suspension car is a different animal and these guys that are getting 14s haven't gotten the knack. Our local track at 925 feet had many '04 in the mid to low 13s stock with 2,000+ DAs.
#86
BTW I had t-top leaking 2 fBods before the GTO. . .
#87
That is correct. Weight difference, IRS, etc is the reason. A stock GTO is fairly rare and is a beautifully appointed car that rides in comfort and a Camaro/Firebird LS1 sounds like a can of loose bolts and the t-tops leak. If someone wanted the fastest stock car they wouldn't pick either one.
Now on the other side, the weather strip on the driver's side is wearing out, and when the rain is very very heavy, I get about one rain drop in per minute, very minor though, barely worth mentioning.
Yeah, the F-bodies do ride pretty rough, I bet the GTO is a much more refined car. Can't get over how ugly they are though, I don't care how fast it is, it's a hideous car and looks like a cross-breed between a Neon and something else, hideous in my opinion.
#88
My Camaro is my first F-body, and while I have read and heard several accounts that these cars do leak through the T-tops, mine is 10 years old with almost 70,000 miles, T-tops are solid, don't leak at all.
