Thinking about switching from a 01 formula to an 04-06 GTO
Hi guys. my name is Chris. I currently have a beautiful 2001 black Formula with 81,000 miles on the odometer. Also has t-tops, ws6 hood, and ws6 wheels. It has an ls2 swapped into it from an 05 gto. The ls2 has about 13,000 miles on it. The tranny is also a built 4l65e not 4l60e. I have a small converter and full bolt-ons pretty much. Now here is what I am pondering. I recently went and test drove an a4 black 2004 GTO. I had 45,000 miles. I liked the car alot. The outside is just ok. The inside is ten times nicer and more comfortable than my 01 formula. I will be seriously looking to step in to a GTO very soon. I will get the 05-06 model if my funds allow for it. I know the 05-06 models have the ramair hood, dual exhaust, and ls2 engine. Are there any other mods that make the 05-06 one better than the 04. Other than what I have previously stated. Also what kind of gearing does it come with and what kind of rear end? I figure it is finally time to step up to a newer vehicle and I would like a brief rundown of the GTO. The pros and the cons of the car for both models, 04, 05-06. Thank you very much and I appreciate any help you can give me.
Wow. 14 views and no replies at all. I guess maybe I should stick with my own kind and keep the formula. Whenever we post things in other sections people do actually respond and give helpful information. I sure hope somebody comes forth and answers some of my questions. Don't be afraid I won't bite.
Other than the LS2 upgrade, hood (non functional) and exhaust outlets, the 2005 and 2006 GTO also has upgraded brakes. The front rotors are 14" rather than the 13" rotors found on the 2004 model. The 2005 and 2006 models also offered 18" wheels. The price difference between the 2004 and 2005/2006 models does not seem to be enough to justify buying a 2004.
I previously owned a 1998 Camaro. Unfortunately, it was stolen in March of 2004. The two cars are different. As you mentioned in your post, the GTO has a much nicer interior. However, the exterior is quite bland (especially the 2004).
http://www.ls1gto.com/forums/index.php has alot more info on the subject and more GTO members that can help. i went from 01 Z28 to a 06 GTO and i have not looked backed. the rear end is a 3.46 i believe for all the year auto and stick. other then their are different colors for the years.
Thank you for the replies guys. Also what is this big fuss people make about the irs on these vehicles. Never launched a car with irs before. Is it really that difficult to do? Also does it break easy? What other possible downfalls or flaws does the car have that you GTO owners would probably know? Just like to try and find out the things I want to know. I basicly would like to hear from GTO owners about what they think is wrong with the car. If anything? Leaning more torwards the 05-06 now as well. Post up please. All your information is very much appreciated.
2006 is the only year the steering wheels controls are lighted. 2006 also inlcuded a power door lock switch, which is located on the center console. The 2006 GTO also has "black" tail lamp assemblies. These seem to be very popular as many 2004 and 2005 owners have switched to the 2006 tail lamps (myself included).
The IRS can cause quite a bit of wheel hop. Narrow tires from the factory do not help. Getting a decent sized tire in the rear is also a pain. Fenders either have to be rolled, or you have to spend a good amount of money on a set of wheels.
oh when you turn the traction control off there isnt a huge light on your dash! personal preference. it is harder to get into the back seats then the fbody but once you get there is is comfortable enough for two people.
The wheel hop caused by the IRS gets tiresome but after you get to know your goat its a thing of the past.
Get yourself some drag bags and you wont have the wheel hop issue. I would say the stock suspension eventually is a let down since the springs start to sag badly. Just get some stock height springs from Pedders, King, or Lovell along with bushings to tighten her up.
Smokin 01 Formula, I've read and read threads like the one you've started and the one that has been suggested to read. I have driven a few goats, from ones with bolt-on setups to heads and cammed cars. All were great! I'am sold on one, I currently daily drive my heads and cam Ws6, I'am buying the goat for a DD.
From the ones I've have test driven compared to the TA, its great. I dont think I'll regret giving up my TA as a DD. I would regret if I got rid of it though.
Do it bro!
Do it bro!
Yeah I am going to. I think the test drive itself made up my mind as far as the decision to upgrage from my f-body. Even though the specific one I drove was an a4 04 model the car was still all around hands down better than my formula.
I know right, I got turned on to goats through a good friend thats one here, (Ls7Junkie) he picked a 06 M6 BOM with 17's. I drove it and was hooked. From power, straight line acceleration, cornering and comfort, wow the comfort. Car was great in every aspect.
The biggest diff's I can come up with.....(never owned a late model F body but have worked on them).
If you do your own motor work / maintentance, the GTO is really quite nice to work on. **** isn't stuffed into the firewall, under the windshield. This meant a lot to me...as I do my own work and time is valuable. Header install on the goat was a 4 hour job, I did the clutch at the same time and took about a full day for everything. Headers and a clutch/converter/cam and this becomes one impressive car quick...whether it's 04 or 05/6.
Rear end...from the factory it ain't well prepared for the drag strip, but if you road race or autocross it's great as-is. The center section I would say is every bit as strong as the Fbody 10 bolt, if not stronger. Ring gear I believe is bigger.
Wheel hop from a standing start is first issue...springs/air bags and no problems. 1 hour or so to do this. Stronger halfshafts are now becoming more affordable, and a recommended upgrade. Easy to change out, when you have the rear end in the air for springs might as well bolt them in.
You might sink $900 in parts for the GTO rear end...but you can upgrade axles/posi/diff cover in a 10 bolt and still splatter the pinion.
Mods are easy, and plentifull, just like any other car out there get it breath right, and work from there
sounds like you have a real nice F-body, the goat will probably be slower do to the fact that it has smaller rear tires, IRS, and I believe it is a little heavier. On the positive side the interior is very nice, not 80's like as the F-bodies are.
One other downfall is since the cars were made in australia and only in the states for 3 years aftermarket parts are at a premium!
