Pontiac GTO 2004-2006 The Modern Goat
H-pipe ????
Old 04-21-2008, 06:25 PM
Ls1Gummi's Avatar
Question H-pipe ????
Can i install a off-road h-pipe with stock manifolds??? Not up on Gto's just wondering the car already has a cat-back. Just want a little more sound.
Old 04-21-2008, 07:11 PM
massillongoat's Avatar
umm I"m not really sure bud cuz of the true duals and all you might have to use and x pipe
Old 04-21-2008, 08:58 PM
thatboyvic's Avatar
yes but if it has a catback it should already have an x pipe
Old 04-21-2008, 09:13 PM
Kamauxx's Avatar
What the???
Old 04-21-2008, 09:17 PM
batboy's Avatar
What catback do you have? Almost all of them already have a crossover, usually a X pipe. No reason to add a H pipe if you already have a X pipe.
Old 04-22-2008, 05:09 PM
Ls1Gummi's Avatar
No it has flowmaster exhaust with all 4 stock cats. I want to get rid of those.
Old 04-22-2008, 06:15 PM
thatboyvic's Avatar
4 cats? wtf... it has 2 cats and a boxed resonator... if it has a catback then it should no longer have a resonator.... post pics man. you have me confused
Old 04-22-2008, 08:50 PM
1BaadGoat's Avatar
Post
I think he is referring the resonators as "CATS" . Have the resonators removed, and put a "H" pipe in or a "X" if you prefer. Lots of people say that the H pipe will give you a deeper tone? I have an H on mine, and love it. Still running factory manifolds/cats but added Flow Master 44's. (That is all about to change though)
Old 04-23-2008, 08:40 AM
CABRO's Avatar
yeah the resonators wont get replaced with the catback...... the first two upfront are the cat's and the two in the rears are the resonators.....if you want more sound just cut out the resonators...... i took mine off and loved it. until i bought corsa sport exh... then i put them back on cause it was way to loud. talk to stolen fox on ls1gto for an excellent h-pipe, if he wont make you one pm me i have one in the closet. just kinda hanging on to it.
Old 04-23-2008, 07:23 PM
1BaadGoat's Avatar
CARBO is correct However Stolenfox is on Hiatus working on parts for the G8. He did mine when he first started doing them, and it is a true piece of work, if you can get one trust me GET IT
Old 04-24-2008, 07:59 AM
LS2tiger's Avatar
If you have a 04 you can use the JBA catless mids with your stock manifolds and really wake it up,but you will have to have the rear O2's turned off.
Old 04-24-2008, 03:59 PM
Ls1Gummi's Avatar
Did it throw any codes when you cut the resonators out??? I got a deal pending on a corsa sport exhaust, if it falls through i'll probably just cut out the resonators out then. Thanks guys for the help.
Old 04-24-2008, 05:12 PM
LS2tiger's Avatar
Removing the resonators will not throw a code. As for the H-pipe just about any exhaust shop will make and install a H-pipe for under a 100.00 .
Old 04-24-2008, 05:26 PM
CABRO's Avatar
yep...no code....
had to remove the h-pipe with the corsa exh....
Quick Reply: H-pipe ????
