Pontiac GTO 2004-2006 The Modern Goat
Who,s on 265/275 rear tires?
Old 06-19-2008, 03:55 PM
LSWONGTO's Avatar
Default Who,s on 265/275 rear tires?
How many people here have a 10 inch rim out back and run 265/275. I want to get driftR 18s and can,t decide between the package with 265or275?
Old 06-19-2008, 05:57 PM
sappy96's Avatar
Quite a few people have 275s. I however am not one.
Just make sure you roll and or cut your fenders
Old 06-20-2008, 01:11 AM
PapaSmurf2005's Avatar
285 Goodyears
Old 06-20-2008, 04:36 AM
LSWONGTO's Avatar
Originally Posted by PapaSmurf2005
285 Goodyears
Did you roll & cut ur fenders or just roll them. I,m guessing I can take the car to good tire shop and have them roll the fenders.What did yall do?
Old 06-21-2008, 09:11 PM
batboy's Avatar
It'll be tough to fit 275 tires and 10" wide wheels under the rear of the GTO. I have 9" rear wheels and 275-40-17 Mickey Thompson tires with Pedder springs and I had to grind the fender lip a little.
Old 06-22-2008, 02:56 AM
Eh, it was not fun.
First thing is first, I already had Pedders 5/16" drag springs. I had already cut the fenders down to the spot welds... that was not doing it so I cut them all the way off. One side rubbed, so I had to have the cradles aligned. Even after all of that the tires are just too tall and bottomed out, so there had to be quite a bit of beating to the inside fenderwells. All in all, they fit.
Old 06-22-2008, 01:55 PM
AlexLs1's Avatar
This is the only draw back with these cars. Lack of tire room.
Old 06-23-2008, 10:05 AM
ArklaTexan's Avatar
I have 9.5" rims with BFG Drag Radials 275, my fenders are cut but more to the offset issues on my 18" aftermarket rims.
Old 06-23-2008, 12:11 PM
sappy96's Avatar
If you have the correct offset you should just have to roll them.
Old 06-23-2008, 09:01 PM
gangbang malloy's Avatar
i have 275 bf drags on the stock 18x8 inch rim with rolled fenders
Old 06-23-2008, 09:24 PM
Not the smartest idea.
Old 06-23-2008, 11:50 PM
Destroyer of Transmissions
1SlowHoe's Avatar
Anybody got pics or a how-to on "rolling/cutting" your fenders. I don't have any idea what you're talking about.
Old 06-24-2008, 12:51 PM
are u talking about the tire bubbling out a little?
its just fine since i wont be doing too much drifting in these.
i've seen worst with guys doing like 305s or something on an 8.5'' wide rim
Old 06-24-2008, 02:56 PM
ArklaTexan's Avatar
Running a tire that wide on a 8" rim is asking for problems. I run a 275 on a 9.5 and would not even consider going to a 295 or 315. There is a reason manufacturers give specific ranges for rim width and tire selection.
Old 06-24-2008, 03:07 PM
LSWONGTO's Avatar
http://www.groupawheels.com/ProductD...f-bd4f3d225473
This is wheel and tire package I want. Do yall know anyone with this setup? Thanks
Old 06-24-2008, 03:31 PM
itslow's Avatar
275/35-18 on 18x9" +52mm offset. Outer lip trimmed to spot welds, some massaging of wheel well on inboard side. Lowered 1/2".
Old 06-25-2008, 12:11 AM
275 on an 8inch rim is fine but borderline IMHO
i understand that the sidewall is being stretched and this tire prolly wont hold up too much for lateral spirited driving but i dont do that at all.
Old 06-25-2008, 04:57 AM
LSWONGTO's Avatar
What rims do yall recomend
Old 06-29-2008, 01:06 PM
Texas Heat's Avatar
I run 275 kuhmo's on one set of stock 17's, and 275 MT's on another set of stock 17's. No issues. But I did roll my fenders, put on drag bags and king drag springs.
Old 06-29-2008, 04:53 PM
Rob
Rob's Avatar
I have the old 19x9 Drift R's in back. Used to run the 275 Toyo's but now run 265 KDW's. No rubbing with either. Quarter not cut or rolled. The BFG 265's are wider than the Toyo's also.
Somewhere along the line, I swapped in King Springs/Koni/Drag Bags. Now there is no chance at all of the tire touching. It might have been close with the BFG's and stock springs/shocks but I think it would have cleared just like the Toyo's.
Quick Reply: Who,s on 265/275 rear tires?
