Pontiac GTO 2004-2006 The Modern Goat
Limp Clutch Pedal
Old 09-24-2008, 10:09 PM
Grn4fbody's Avatar
Default Limp Clutch Pedal
Does the 04 GTO have the same annoying clutch pedal problem that the LS1 Fbody's have?
My buddy's just did it and I thought the 00+ cars didn't have that problem?
Old 09-25-2008, 12:25 AM
Summerwolf's Avatar
what annoying clutch pedal problem are you talking about?
Old 09-25-2008, 12:44 AM
Grn4fbody's Avatar
With the Fbody's when the clutch get's hot the pedal will go limp. And the Drill mod is the only thing to fix it,or buy a aftermarket Clutch Master Cylinder
Old 09-25-2008, 01:01 AM
thatboyvic's Avatar
its the slave on the goats that causes that... also the hydrolic lines. get a new slave, stainless lines and a good clutch and it will be all gravy
Old 09-25-2008, 02:03 AM
Summerwolf's Avatar
I never had an issue, when I replaced my clutch I replaced everything else too and still don't have an issue....I autox my car a lot too.
Old 09-25-2008, 07:59 PM
04BlackGmc's Avatar
never a issue here at all
Old 09-25-2008, 11:28 PM
thatboyvic's Avatar
I never had an issue till I had 446hp
Old 09-25-2008, 11:33 PM
Summerwolf's Avatar
lol.....bastage.
Old 09-27-2008, 01:40 AM
thatboyvic's Avatar
put your cam in
Old 09-27-2008, 10:28 AM
TAwhore's Avatar
change the clutch fluid
Old 09-27-2008, 04:51 PM
thatboyvic's Avatar
yep check the resevoir its probably black and has gunk.
Old 09-27-2008, 10:34 PM
ULTIMATEORANGESS's Avatar
mine has done this a few times after hard shifting. then its fine.
Old 09-29-2008, 07:29 AM
Grn4fbody's Avatar
Yeah the fluid is BLACK, can we power suck it out or do we have to take the tranny out to flush it all out?
Old 09-29-2008, 04:59 PM
dkrowner's Avatar
11mm socket on the bleeder valve which right above the line going into the tranny on the drivers side
Quick Reply: Limp Clutch Pedal
