Brake cleaner safe on rubber seals? - LS1TECH
Thread Tools Search this Thread
Old 02-07-2009, 10:33 PM   #1
Firebirdfan's Avatar
Default Brake cleaner safe on rubber seals?
Hey guys. Got a quick question. With my college's SAE Baja project, we bought some used brakes calipers. They're kind of crapped up with dirt and some other stuff (maybe a bit of corrosion). I took the calipers apart, but there's a few rubber orings/seals that I'd really rather not risk removing (they're CRAZY expensive to replace). I was wondering if some standard automotive brake cleaner, aerosol or otherwise, is safe for the rubber seals. I don't want to degrade the seals and have them fail later on during competition. Is it safe to use?
Firebirdfan is offline   Reply With Quote
Old 02-07-2009, 11:09 PM   #2
black_sunshine's Avatar
you could always use carb cleaner. I think the carb cleaner should be safe on rubber. I use it everywhere i am iffy about rubber and plastic.
black_sunshine is offline   Reply With Quote
Old 02-09-2009, 12:29 PM   #3
why not use some mild soap & water?
beerwhiskeyjoe is offline   Reply With Quote
Old 02-09-2009, 01:34 PM   #4
brake parts cleaner is made to be compatible with the rubber seals used where brake fluid is present
brake cleaner is fine you dont have to reinvent the wheel
1994Z28Lt1 is offline   Reply With Quote
Old 02-09-2009, 07:40 PM   #5
Dont use it on rubber that is not made for taking any harsh chemicals. That cancer in a can stuff will eat right through it or discolor it forever.
sdbrown84 is offline   Reply With Quote
Old 02-09-2009, 09:35 PM   #6
LSX Mechanic
Damian's Avatar
Brake Cleaner is perfectly fine for what you need. I use Brake clean to clean almost EVERYTHING automotive related.
Damian is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Canton Valvecovers.. what gasket? 1badzee LT1-LT4 Modifications 16 07-05-2009 07:47 PM
Anybody done their rear brake lines all the way from distribution block to caliper? dhdenney LT1-LT4 Modifications 23 03-02-2009 07:42 PM
New rubber boots for brake caliper slider pins Weezzer General Maintenance & Repairs 7 03-16-2006 07:32 PM
Guide to Painting Your Brake Calipers!!! Onyx Z Appearance & Detailing 9 08-05-2003 09:07 PM
GUIDE TO PAINTING YOUR BRAKE CALIPERS!!! SLPFireChicken Appearance & Detailing 11 01-06-2003 02:23 AM
Tags
auto, automotive, brake, clean, cleaner, cleaners, parts, plastic, rbber, rubber, safe, safw, seal, seals, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
