Seafoam and Race Gas - LS1TECH
Thread Tools Search this Thread
Old 06-09-2010, 11:33 PM   #1
RikkiTorment's Avatar
Default Seafoam and Race Gas
Hey guys, I've been having a bit of "engine run-on" in my 00 Z28 with 68k miles. I'm trying to debunk why my car is doing it, so I am going small steps before drastic steps. And I was wondering if it is a bad idea to Seafoam my car(minus putting it in the oil), and then put 100 Octane in it that same day?
-Edit: Or even Seafoaming at all for that matter?
RikkiTorment is offline   Reply With Quote
Old 06-10-2010, 12:20 AM   #2
180ls1's Avatar
uh running 100 octane wont help i dont imagine, if there are no codes i would suggest running fuel injector cleaner and making sure your fuel filter has been replaced. If you do seafoam the car i would suggest also replacing the plugs, wires and o2 sensors that is good general maintenance anyways.
180ls1 is offline   Reply With Quote
Old 06-10-2010, 12:32 AM   #3
Douchebag On The Tree
justin455's Avatar
Quote:
/thread...this should be in general maintenance anyway
justin455 is offline   Reply With Quote
Old 06-10-2010, 12:47 AM   #4
ЯєŧąяĐ Єlímíиąŧ°я Ö
orangeapeel's Avatar
Seafoam wont harm anything. Just pull off the vaccuum hose from the brake booster and dump half a can in while running. Shut it off on the last big gulp. Take the deep creep spray and blast all inside the intake/tb as deep as you can get it. Full tank of gas = ~half can~ (Depending on how many gallons). Other half in the oil. More it smokes after about an hour or so of sitting the more it is burning off.
replacing O2's is not "general maintenance". If they arent messing up don't mess with them. Seafoam in no way/shape/form will harm the O2 sensors.
orangeapeel is offline   Reply With Quote
Old 06-10-2010, 12:47 AM   #5
X-ray's Avatar
What's the 100 octane for? If you don't need that octane, there is no point in using it as that is just an anti-detonation rating and does not burn any cleaner.
X-ray is offline   Reply With Quote
Old 06-10-2010, 12:59 AM   #6
ЯєŧąяĐ Єlímíиąŧ°я Ö
When someone says "race gas" I generally think "leaded fuel".
Old 06-10-2010, 01:03 AM   #7
My friend is set on thinking that I have a vacuum leak, so I am going to have at it with a propane canister.
Related Topics
Thread Thread Starter Forum Replies Last Post
How To Seafoam Your Car ChocoTaco369 General Maintenance & Repairs 1155 03-24-2017 02:02 PM
Low Oil Pressure After Seafoam? Huntr1117 LT1-LT4 Modifications 21 01-17-2017 04:58 AM
Seafoam question, deep creep in spark plug holes? Ferocity02 General Maintenance & Repairs 12 11-10-2012 05:39 PM
Did seafoam, now high rpm miss?? 93BlackZ28 LT1-LT4 Modifications 13 07-10-2006 10:24 PM
Tags
19380, gas, locations, race, seafoam
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
