Can an LS1 swap into an LT1 car pass OBDII emissions??? - LS1TECH
Thread Tools Search this Thread
Old 02-25-2011, 10:30 PM   #1
BIG BAD BLACKSS's Avatar
Default Can an LS1 swap into an LT1 car pass OBDII emissions???
I was about to apply for my "race car exemption" from Illinois, and noticed all the threads about LS1's being reprogrammed to pass when they posisbly shouldn't be. Got me wondering how much effort it would take to get an LS1 swapped into an LT1 car to pass??? It is a newer cleaner motor in an older car, and is a few cubes smaller. Which I believe they say is allowable for a motor swap here in IL. Just not sure if the OBDII scan would throw up any flags if programmed to pass?
I do have Speed Inc locally that I could have look at the car for me if needed. Just wondering on the feasibility of this before I bother anyone over there. Figure someone here has to have done it before.
BIG BAD BLACKSS is offline   Reply With Quote
Old 02-26-2011, 01:18 AM   #2
9WhiteCamaro9's Avatar
Here in NC, you either have to swap the motor with the same year or newer or it has to be newer than the previous motor, I can't remember.
9WhiteCamaro9 is offline   Reply With Quote
Old 02-26-2011, 07:48 AM   #3
I8ASaleen's Avatar
Quote:
Same here in TX
I8ASaleen is offline   Reply With Quote
Old 02-26-2011, 10:44 PM   #4
Rockstar
Johnny-LT1-runner's Avatar
There are laws regulating engine swaps? Who the **** is gonna be smart enough to know the difference? They work for the state!!
Johnny-LT1-runner is offline   Reply With Quote
Old 02-26-2011, 11:40 PM   #5
LS1Adam84's Avatar
I don't see why it would be an issue, honestly when you swap the LS1 in, you will need the LS1 harness, therefore all the functioning systems from the LS1 pcm will show on the OBD2 scan and it won't say this is not and LT1 harness the OBD2 should just pick up whether certain systems are pass or fail. If they are tuned out it will show as a pass, if they are not tuned out but all sensors are good and plugged in then it will show as a pass.
Then again I could be wrong.
LS1Adam84 is offline   Reply With Quote
Old 02-26-2011, 11:53 PM   #6
I don't see why it wouldn't pass. You could just tune everything out.
skorpion317 is offline   Reply With Quote
Old 02-28-2011, 09:36 AM   #7
On the tree
Most state end federal laws require same year or new engine for a replacement. As long as you can get all of the systems working correctly and all SES lights off and self test to run and comeback as complete then you should be able to pass.
Sneakyws6 is offline   Reply With Quote
Old 02-28-2011, 02:35 PM   #8
Super Speed's Avatar
If you make it look like a stock install the tech will more than likely (99%) not know there has been a swap. The only thing I can think of is if they plug in an obdI and it doesn't read anything since it will now be OBDII...
Super Speed is offline   Reply With Quote
Old 02-28-2011, 04:01 PM   #9
z_speedfreak's Avatar
well in my strict state of taxachusetts when it comes to engines as long as you don't throw a code you pass. I ditched the dual cat set up for a less restrictive single cat set up, ditched the AIR & EGR and have never had a problem cause its all tuned out of the pcm
Quote:
as far as I know they can't plug into an OBDI vehicle. we used to have rollers with a sniffer for '95 and earlier vehicles which the state did away with 2? years ago for cost reasons(those systems always had problems too). now they don't bother checking emissions for OBDI vehicles.
z_speedfreak is offline   Reply With Quote
Old 02-28-2011, 04:05 PM   #10
StrobinSS's Avatar
Yes it can pass. Buddy did an LS1 swap with his 97 and passes.
StrobinSS is offline   Reply With Quote
Old 02-28-2011, 04:34 PM   #11
WSsick's Avatar
Have a friend that can pass you.
WSsick is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Changing the VIN in pcm to pass OBDII test in swap vehicle? Shoaf85 PCM Diagnostics & Tuning 17 03-20-2017 06:02 PM
Methods to pass OBDII inspection makeyourowndestiny PCM Diagnostics & Tuning 6 02-19-2016 05:31 PM
OBDI lt1 to OBDII ls Z20ATE Conversions & Hybrids 2 02-09-2012 01:12 AM
s10 lm7 swap zx2ner25 Conversions & Hybrids 14 06-17-2011 05:29 AM
LT1 to LS swap questions A. T Conversions & Hybrids 5 03-16-2010 11:49 PM
Tags
carolina, cars, cat, delete, emisions, emission, engine, ii, il, ls1, north, obd, odb, pass, swap, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
