Can someone explain displacement to me? - LS1TECH
Thread Tools Search this Thread
Old 02-17-2017, 05:11 PM   #1
Default Can someone explain displacement to me?
Just so I have a full understanding, if the AFR is at Lambda, is displacement the measure of how much air and gas is worked after one full engine rotation (or after four?) which means you could derive how much fuel is spent per rotation if you are at perfect AFR?
SouthernRex is offline   Reply With Quote
Old 02-17-2017, 06:08 PM   #2
AgFormula02's Avatar
Displacement = bore x stroke
as far as what you are getting to, yes.
The PCM determines how much air is flowing in to the engine And determines how much fuel to add for a requested A/F ratio.
So yes, you can do some math and determine how much fuel you need for a given displacement at a given rpm for a given a/f
AgFormula02 is offline   Reply With Quote
Old 02-21-2017, 01:19 PM   #3
1CAMWNDR's Avatar
I think you may be confusing displacement with volumetric efficiency.
1CAMWNDR is offline   Reply With Quote
Old 02-21-2017, 01:49 PM   #4
Per google:
Engine displacement is the swept volume of all the pistons inside the cylinders of a reciprocating engine in a single movement from top dead centre (TDC) to bottom dead centre (BDC). It is commonly specified in cubic centimetres (cc or cm3), litres (l), or (mainly in North America) cubic inches (CID).
OSU Football Fan is offline   Reply With Quote
Old 02-21-2017, 04:28 PM   #5
-Ross-'s Avatar
-Ross- is online now   Reply With Quote
Old 02-22-2017, 03:10 AM   #6
I know the more "cid" you have....the more power you will make. Thats all I know for sure.
lol
LS6427 is online now   Reply With Quote
Old 02-22-2017, 04:57 AM   #7
bufmatmuslepants's Avatar
It's (pi * bore ^ 2) / 4 * stroke, you take the area of the piston, times the stroke. Volume of a cylinder is pi * radius squared, * height which is stroke. Displacement is how much volume each cylinder has, times number of cylinders. For a standard small block Chevy, bore is 4" and stroke is 3.48", so half bore is 2", squared is 4", times 3.14 is 12.56 inches squared is the area of the piston. Multiplied by height of the stroke is 12.56 * 3.48 is 43.7 inches cubed being the volume (displacement) of 1 cylinder. Multiply that by 8 cylinders is 349.6 inches cubed, which is ~ 350 cubic inches, small block Chevy. That's how much air a 350 cubic inch engine can injest. Since combustion (the bang part) requires air and fuel, the more air and fuel you can injest, the more power you can make.
To make up for small displacement, you can cram more air down an engines throat with boost, since air is compressible (water is not). You can take 1 cubic inch of air, and squeeze that air with more pressure, and it gets smaller, so if you squeeze the air before cramming it into the motor, you can fit more. Pretend it's laundry. If you just dump your clothes hamper into the washer, you might only fit half of your clothes since they are not compressed. If you cram the clothes into the washer and maybe jump on top of your clothes (putting pressure on them) you make them smaller and can fit more clothes in the washer, and you can get more work done in a smaller amount of time. However if you try to do too much work in too small amount of time, like too much laundry in the machine, or too much air in the cylinder (too much boost) you'll watch that washing machine explode or your cast stock pistons explode. If you get a bigger washing machine, you can do more work without pushing it beyond its limits, so increasing displacement increases the potential work done. You can also have a huge washer and do a small load of laundry (tiny heads and cam restricting amount of air able to fit through the runners to fill the cylinder) so just because you increase displacement, doesn't automatically mean you did more laundry, you have to put that laundry in there. Another factor is the mixture of air and fuel, fuel being detergent, just because you cram a shitload of air or laundry in, doesn't mean you left good room for mixture with detergent or fuel, this is where port velocity of heads and swirl comes into play. Displacement increases the POTENTIAL for power, eventually as you cram more and more boost and fuel into a motor, you start leveling off on power, law of diminishing returns. If you held your hamper 6" above the washer and dumped it in, vs holding your hamper 6' above your washer, the momentum of the clothes landing in the washer compresses some of them and you fit more, so higher port velocity in a head helps fit more air into a cylinder, like more clothes velocity.
The air in an engine is sucked into the cylinder, as the piston goes down on the intake stroke with the valves open and throttle body open it creates a vacuum and sucks in the air. When your throttle blades are only a tiny bit open, but you are at 2000 rpm, it can only suck in a tiny bit of air, and you do less laundry (cruise steadily at 30mph because you are only taking in a little air and therefore making small horsepower from a small bang). If you go wide open throttle, you can suck in more air since the the hole to get more air from, the throttle blades, is bigger, so you make more power and accelerate. 350 cubic inches is the ideal conditions amount of air your motor can injest, but it's restricted by the flow path. That's why adding bigger heads or a bigger cam that leaves the valves open longer makes more power, it allows more air to fill the cylinder to get you closer to the ideal 350 cubic inches of air (volumetric efficiency).
bufmatmuslepants is offline   Reply With Quote
Old 02-23-2017, 11:19 AM   #8
KCS
Moderator
KCS's Avatar
Quote:
Not exactly. Displacement is simply the volume of space the piston moves as it travels from TDC to BDC and vise versa. Lambda isn't based on volume, it's based on mass. The mass of oxygen consumed by the engine varies throughout the RPM range and across different atmospheric conditions. That's why sensors are used to measure it.
KCS is online now   Reply With Quote
Old 02-28-2017, 11:08 PM   #9
Thank you for the replies guys, that was super informative.
Old 03-01-2017, 04:40 PM   #10
TheUrbz's Avatar
If you dont mind rex, id like to hijack, this since it looks like you got your answers, with a pretty dumb question. What is the importance of displacement? A lot of the threads i see about making power, its all bolt ons or modding a regular 350. As it has been explained to me for my wants and needs i should go 383. But the 350 threads say they can make the same if not more power with a 350 rather than going 383.
Now with stroking you get more torque yes. But my feeble mind cant find why thats important for the NOT drag racing applications. The powerband seems to be all up on the high side of the charts, tq usually following the hp line. With the 350 it starts low then climbs rapidly. Whats the importance of having that difference in powerbands. Again this is probably engine 101 stuff, but im feeling like this-
TheUrbz is offline   Reply With Quote
Old 03-01-2017, 06:32 PM   #11
More displacement gives more POTENTIAL for power. Same size heads though, same cam, on a 383 vs a 350, not much difference in power. Just because you have a bigger washing machine doesn't mean you are doing more laundry, you have to put more laundry in there. You CAN do more laundry with a bigger machine, that's the POTENTIAL part, but if you put 1 weeks worth of clothes in a normal washer vs 1 weeks clothes in a super jumbo washer, you still only did 1 weeks worth of laundry. Same size heads (area for air to enter through) and same cam (time valves open and lift), and you are bringing about the same amount of air into the cylinder. There's a slight difference, very tiny, due to the increased vacuum of a little more area, but really you are sucking through a straw. If you had a midget and a giant have a contest, who can inhale the most air through a McDonald's straw in 1 second, it would be about a draw since the straw is the restriction, neither gets a full breath. Give them each a paper towel roll and the giant will win since he'll finally get a full breath. A STOCK motor is restricted by a straw called emissions, noise, and fuel economy. Since we don't care about those, give your motor a paper towel roll before you make it a giant breathing through a straw. Midget with a paper towel roll gets more air (and power) than a giant breathing through a straw.
Old 03-01-2017, 09:11 PM   #12
NewOrleansLT1's Avatar
I like how you broke that down ^^ 100%
NewOrleansLT1 is offline   Reply With Quote
Old 03-01-2017, 09:13 PM   #13
But 350 vs 383 giving all things are the same the 383 should make roughly 30hp more.. I don't have any proof.. Just going off word of mouth..
Old 03-02-2017, 06:45 AM   #14
TheUrbz's Avatar
Quote:
thats partly what im missing. yea if you stroke an engine but not change a damn thing else youre wasting your time. but as you say, if you built them equally, your gain might be 30 more horses. the hells the point then. the point im told is tq and the difference in powerband. fantastic. again, why would that be important. you take a 350, mod the hell out of it, then rev it up higher than the national debt and you got lots and lots of power. Stroked engines dont rev high. i have seen exceptions but in general, there not for reving. so i dont know why going through all that work to have POTENTIAL but you can get the same out of a 350.
Old 03-02-2017, 10:13 AM   #15
KCS
Moderator
KCS's Avatar
Quote:
It all goes back to the formula for HORSEPOWER:
HP = TQ x RPM / 5252
The number 5252 is a constant, so the only way to make more horsepower is to increase torque and/or RPM. When you increase displacement, you increase the overall torque output, so the horsepower throughout the RPM range actually increases too.
If the camshaft and/or cylinder heads are not changed to compliment the larger displacement, the peak horsepower stays the same, but you WILL go faster because the overall power between gear shifts has increased. Driving around on the street is nicer too because you have more power available at lower RPM so you don't have to change gears and buzz up the RPM just to pass a car on the street.
The stock LS7 small block from GM has a 4" stroke crank and has a 7k RPM redline. Many 4" stroke 408ci combos turn well into the 6500-7500 RPM range in street applications. Drags racers are even turning over 8k with almost 5" of stroke in some classes (IHRA PS for example). Those aren't exceptions, that's the norm! Saying "stokers are not for reving" is one of the most false statements I've ever read!
Old 03-02-2017, 11:36 AM   #16
TheUrbz's Avatar
Quote:
damn yea. i havent really looked into what their making with what now, i was just going off of some of the things ive read about keeping a 383 N/A. i tried to get into ford stuff for awhile but then i started on GM so my small view comes from reading about baseline LS/LT1's. so come to find out im the exception. preciate the info.
i will happily agree with anyone who will call me a damn idiot, but ima do my best to have it make sense to me. peak HP will stay the same but i will go faster. so that being said its the acceleration of the vehicle that gains when you change the displacement due to the higher availability of torque leading to the higher average beginning availability of hp when starting from a low rpm. ...did that make sense? so where is that in applicable comparison to a strung out 350? would the 350 be faster in the top end? a higher top speed?
i dont get a lot of GM experience where im at. youtubes great but its just TV basically. there is no opportunity for me to physically see or experience these comparisons. all my douche friends drive/want lifted trucks. im the only one that wants to "drag ***" as they say.
Old 03-02-2017, 03:33 PM   #17
KCS
Moderator
KCS's Avatar
Since we're on an LS site, let's compare typical LS displacements. A 450hp 383ci LS1 (3.905" bore x 4" stroke) will accelerate faster than a 450hp 347ci LS1 (3.905" bore x 3.622" stroke) because of the extra overall power, and it might be able to manage a higher top speed because you can use a numerically lower gear. I'll admit, I'm not really sure about that one though.
Old 03-02-2017, 09:29 PM   #18
JD_AMG's Avatar
Im going to make this really simple, torque moves the car, horsepower is just a human calculation for work.
This is backwards. An engine dyno reads torque then calculates hp from it. Torque is what is real and is what you feel, your cars acceleration follows the torque curve exactly, and gears multiply torque.
Example, why is 1st gear so much more punch than 2nd gear? Because 1st gear multiples torque more than 2nd, 2nd more than 3rd, 3rd more than 4th and so on.
And if you are making more torque at 3500RPMs than 4500RPMs, then you will accelerate harder at 3500RPMs even though hp is lower. *note* this does NOT mean you should shift at 3500rpms or if you have a CVT it should stay at 3500rpms.
Then what does hp "do"? Thats where gearing comes back in to play, its about maximizing the gearing available. Remember how 1st pulls harder than 2nd? Well you don't want to shift early and loose all that extra torque at the wheels from the previous lower gear. You don't shift a peak torque because you want to maximize what that gear for the torque you make, and peak hp tells you when the maximization is best for the gear.
Another easier way to think about it is when riding a 10 speed bicycle. 1st gear gets you going really easy (lots of torque multiplied) but you don't want to shift early as its harder to peddle then (lost some of the torque multiplier) but if you are peddling crazy fast just to maintain speed you didn't maximize that gear (hp) and should have shifted already.
JD_AMG is offline   Reply With Quote
Old 03-03-2017, 07:51 AM   #19
TheUrbz's Avatar
Quote:
i honestly could have said HP following the TQ line, thats just what i typed first.
so although the "power" is the same, the ability to lay it down is what the advantage is for stroking. so witha 350 and a 383 having the same HP, they will have the same top end, but the 383 will get to it faster, right?
Old 03-03-2017, 03:06 PM   #20
Quote:
BUT....I had the same top end that you see in my sig on my first LS6 stroked engine, which was a 436ci... (4.1 bore x 4.125 stroke)....basically terrible 1998 LS1 heads flowing 304cfm @ .650, terrible stock 1998 TB and ported LS6 intake. 1 7/8" LTs.
I put all of this on my new engine....390ci. My 436ci blew up.....I had a 390ci built and installed. Absolutely no other changes except the cam.
So...Only change.....different cam. The 436ci had a rather mild, stock-like, smooth idle: 242/242 .610/.610 114 lsa. Nothing big at all.
390ci has the new cam in my sig.
So, same air flow capability.....but the 436ci had A LOT more power to pull air through faster.....like being force-fed without boost. More CIs did the work on the 436ci.
Same exact 4L60E tranny, same rear-end, gears, wheels/tires.
436ci made 500 RWHP/500 RWTQ.......
390ci can only make 410 RWHP.
So...its apparent that if absolutely nothing changes on the air-flow potential side of things (TOP END FLOW ABILITY).......the more CIDs you have, the more power you can make through brute strength. You don't really need to have a better top end capable of more air flow to make more power.......
More powerful pistons will pull the air through faster to make more power.
It won't be as efficient as the 390ci...but more power will result with just increasing CI's.
So I guess if I understood your post correctly.......I would add that you don't necessarily have to do more laundry to make more power....you can also move the laundry through much faster to make more power also.....
I think.....Now I'm getting confused.......
Related Topics
Thread Thread Starter Forum Replies Last Post
Need help doing my homework. IDRIVEAG8GT Generation IV Internal Engine 13 04-01-2011 03:32 PM
boost vs cubes ayousef Forced Induction 27 08-10-2008 08:39 PM
Whats the displacement on a 383? Siphon LT1-LT4 Modifications 6 06-13-2005 08:42 PM
Ricers - Give up the whole displacement arguement! Delux247 Racer's Lounge 35 03-11-2005 10:48 AM
Is a higher cfm head really better for turbo? rodent Forced Induction 13 08-29-2004 09:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
