Fluid hose coupling help - LS1TECH
Thread Tools Search this Thread
Old 02-24-2017, 09:44 PM   #1
Default Fluid hose coupling help
OK, so the connection to my water pump on my CPU liquid cooling kit snapped off. Buying a new kit would be time consuming and more expensive... So I have an idea. There is still plenty of room to hose clamp at where it broke but it is wider ID and OD then the hoses in the system. Is it possible to couple a smaller ID\OD hose to a bigger one?
SouthernRex is online now   Reply With Quote
Old 02-26-2017, 06:23 PM   #2
Well, I ordered the water pump, but it ended up being the wrong size hose anyway. DOH.
So, trip to Lowe's and all is good again.
Old 02-27-2017, 01:45 PM   #3
Eric Trujillo's Avatar
You need to take that bitch apart and clean it, before it gets really bad. Remember, dust acts as an insulator which will only make your components run warmer over time.
Eric Trujillo is offline   Reply With Quote
Old 02-27-2017, 06:16 PM   #4
Yeah, I ran an air gun through the heatsinks and exposed circuits and fans. It's definitely seen better years, though.
Old 02-28-2017, 12:19 AM   #5
Funny enough, I ran into a leak on what I built. Thank God I didn't lose my $500 video card in the process, but I put plumber tape on the hook up and I'm good to go so far. Next PC build I'm going with a company that uses American ******* measurements. (Seriously, nobody in this state carries this bizarre Korean ID/OD that came with the kit.) Yes, that's right, I'm not going back to air-cooling. It's kind of a "once you do this you can't go back" kind of thing. I have to liquid cool something, or it's not a real gaming PC.
Old 02-28-2017, 09:09 AM   #6
What are you liquid cooling? is it just the CPU?
Old 02-28-2017, 01:24 PM   #7
Quote:
yeah. I had my gpu on the loop but when i upgraded the fitting for the heatsink (and by proxy waterblock) was different so now its just cpu
Old 02-28-2017, 04:23 PM   #8
Get an AIO Liquid cooler and call it a day dude. This is what I use and its been working just fine.
http://www.corsair.com/en-us/hydro-s...uid-cpu-cooler
Old 03-02-2017, 06:27 PM   #9
I might go closed loop next PC build (which since I maxed Doom 4 in 4k @ like 300FPS+ I haven't been able to convince the wife that we need a new one just yet.) I really loved this system though, it lasted for years and years and years with 24/7 run-time and overclocked parts.
Related Topics
Thread Thread Starter Forum Replies Last Post
radiator hoses 04Z06vette Conversions & Hybrids 3 09-16-2016 07:18 AM
AN Fitting Into Braided Line.. Wrong Fitting? Or Bad Hose? TXjeepTJ Fueling & Injection 4 04-08-2015 01:55 PM
Using PowerGrip hose clamps with fuel line claytonisbob Conversions & Hybrids 2 10-08-2010 10:55 PM
Intake ducting elbows thunderstruck507 Conversions & Hybrids 10 03-30-2009 08:06 PM
Lets talk/rant about coolant hoses Chris95Z LT1-LT4 Modifications 17 12-10-2008 11:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
